01-20-2023, 04:27 PM | #1 |
Rep 71
F30 vs F80 Speaker fitment
Is there any difference between the doorcards on the F80 versus an F30? I notice that Crutchfield states a larger variety of speakers fit as midrange replacements, namely the Focal K2 ES100K components, as being available for an F30 Harmon Kardon versus F80 Harmon Kardon.
I can't imagine it's a big deal, but I have only been burned in past lives where I had thought I knew more than Crutchfield. Is there something I'm missing here? Anyone have any feedback on how they've fitted Focal K2s specifically? TIA. |
01-23-2023, 12:32 PM | #2 |
Rep 1,117
All F Series M3/M4 (at least in USA) have HK Audio Option as standard. These speakers are 100% the same as the F30/F32 with HK OPTION. You can tell by the tweeters on the bottom of the A Frame.
From there it gets murky. F30/F31 HiFi Option doesn’t have all the same speaker placements as the HK System does. Like the A Frame Tweeters. Or the Tweeters on the rear side door. Same with basic. You didn’t ask this, but need to know. It even gets murkier when you get into the Speakers impedance, also called resistance. iirc, the basic, Hi-Fi and HK all have difference impedance on the speaker sets and amps. So yes, some speakers are in theory non-compatible. Looking at the Crutchfield page for the speakers you are looking at, correct or not, it states they are all 4 Ohms. I *believe* they are replacements for the HiFi Speakers, but it’s honestly been years since I checked the specs of the different lines. I seem to remember the HK possibly had a different resistance for at least the under seat sub, but could be incorrect. That might explain why they list the F30 but not the F80. So you really need to pull the 3 different speaker types, unplug them and check them with an ohm meter to be sure of resistance, unless someone recalls FOR CERTAIN the values of the HK Speakers Options in the F80/F82. |
01-23-2023, 11:25 PM | #3 | |
Rep 71
NealfromNZ554.00 |
01-24-2023, 03:21 AM | #4 |
Rep 538
The es100k are only 3 mm deeper that the custom fit ISBMW100Ls which is listed for both F30 and F80 fitment A custom spacer will sort that. Just needs some attention between the door card mount for grill and speaker surround face. Just need to think about a draught seal of some kind depending on how thick the custom spacer is.
Other area is the tweeter on the es100k needs to be taken out of its case and a custom ring added so it clips into Hk mounts. A person on here sells adaptor rings for the tweeter and mid base for an e90 setup. The tweeter ring should work, but not sure about the mid bass adapter as e90 mounts to door card rather than door. |
RhinoComp34.50 |
01-24-2023, 11:06 AM | #5 | |
Rep 1,117
RhinoComp34.50 |
02-01-2023, 03:40 PM | #6 | |
Rep 71
02-01-2023, 07:38 PM | #7 |
Rep 538
There was also a uk company that 3d prints f30/f80 woofer rings for es100ks that I came across recently. They don’t ship down under but might be useful to yourself.
https://streetwise3d.com/products/bm...-adaptors-pair |
RhinoComp34.50 |
02-01-2023, 07:55 PM | #8 | |
Rep 71
There appears to be an eBay seller named bmwhaus_uk which ships worldwide, but otherwise it seems like I’m getting closer and closer to buying an Ender 3…
G05 - 2019 X5 xDrive 40i, Black Sapphire Metallic over Extended Merino Coffee
BMW's not forgotten: *F80 - 2018 M3 ZCP, 6MT* *F15 - 2017 X5 xDrive35d* *E82 - 2008 135i, 6MT* |
02-01-2023, 09:37 PM | #9 |
Rep 538
Thinking similar on the 3D printer. Cost of purchase and fright via freight forwarder is similar to a printer.
Either that or make adaptors out of ABS plastic chopping board or use MDF and utility vehicle bed liner waterproof paint. This could be a good base file for 3D printing and adapting to es100k bolt holes for F80 / F3X platforms. https://cults3d.com/en/3d-model/vari...eaker-adapater |
03-29-2023, 01:40 PM | #10 | |
Rep 538
If you contact this seller ( streetwise3d ) via their web page they will ship internationally. |
05-28-2023, 07:45 PM | #11 |
Rep 538
Here’s the streetwise adaptor for es100k in F8x f3x doors for anyone following this thread. Website has international shipping now.
Well made with excellent fit. Just received 4 of them |
