01-11-2009, 05:29 PM | #2 |
Rep 448
I have the same question. But I want to know which is the best set-up for a daily driver and monthly track car combo like I use my Z4M Coupe.
TC Kline DA vs KW Variant 3 coilovers vs Bilstein PSS9 Thanks. |
01-13-2009, 07:06 AM | #3 |
Rep 962
im pretty sure they don't make the blistein pss9 for the m. The TCK would be better for the track, but i don't no about the kw. Ask O-Cha about his tck d/a coliovers. I talked to him about it and he seems to like them.
01-15-2009, 01:43 PM | #4 |
Rep 448
01-15-2009, 02:05 PM | #5 |
Rep 962
i believe that those are for the z3 m coupe. I might be wrong. It says: Condition
also fits 318ti, and Roadsters, and non-M cars the 318ti hasn't been around for a while, around the z3 time period. Ill email them and find out.
01-15-2009, 08:01 PM | #8 |
Rep 962
http://www.bimmerfest.com/forums/sho...d.php?t=321380
http://www.bimmerfest.com/forums/sho...d.php?t=333796 hopefully this helps.
01-15-2009, 11:24 PM | #9 |
Rep 4,726
For you between the kw and tckline I'd get the tckline, I don't know enough about the bilsten though.
01-16-2009, 12:19 AM | #10 | |
Rep 448
01-17-2009, 05:21 PM | #11 |
Rep 339
if you do not track the car alot, i'd stay away from the tck. KW has a variable spring rate, meaning it can be slightly softer around town, but will tighten up as your driving becomes more agressive
01-18-2009, 09:04 PM | #12 |
Rep 4,726
I disagree greatly. On full soft my DAs ride better then stock, and that's on 500/600 springs. KWs are for people who want to drop their car super low and ruin the handling, they have no real benefits besides that.
01-19-2009, 02:54 PM | #13 |
Rep 339
i hardly dropped my car at all, and the handling has become slightly better. i imagine it would suck if i dumped it, but thats dumb in the first place. i wanted to get TCK's my self, but was able to pick these up for 1700
01-19-2009, 04:20 PM | #14 |
Rep 448
01-20-2009, 12:08 AM | #15 |
Rep 448
01-20-2009, 06:37 AM | #16 |
Rep 962
here is the link for the ground control suspension...
http://www.ground-control-store.com/...ion.php/II=774
01-20-2009, 02:23 PM | #18 |
Rep 4,726
I didn't say that, I said not as good as the tckline will with minimal to zero benefits to make up for it.
01-20-2009, 03:50 PM | #19 |
Rep 339
01-20-2009, 04:47 PM | #20 | |
Imola Lover
26
Rep 749
01-20-2009, 06:50 PM | #21 |
Rep 962
01-20-2009, 08:19 PM | #22 |
Rep 4,726
In reference to slamming the car, do you not know how to read entire sentences? If you slam a car onto it's tires you'll mess up the geometry so much it will handle horridly. Doesn't mean you have to with the KWs, but thats the reason most people buy them, because you can do that, where as with a lot of other setups you'll run out of adjustment.
