03-08-2023, 07:54 AM | #1 |
Rep 10
Display errors on start up with my M4 2015
To give a little background, I had a Racechip Black GTS, catless pipes, spark plugs and cold air intake installed on my car back in 2021. A week or so after, I started getting Drive train malfunction error randomly. Now, for the last few months I've been getting tons of errors popping up on my display whenever I start the car up and have to clear them all.
I'm attaching pictures here but they are: Frontal collision warning system Inactive Rear axle differential lock reduced Pedestrian warning Malfunction Chassis stabilization Any idea where I would even begin to figure out what's going on with this? |
03-08-2023, 08:39 AM | #3 |
Rep 10
03-08-2023, 08:40 AM | #4 |
Rep 1,015
If you cant find someone local who can scan it for you, i would recommend bimmerlink.
03-09-2023, 02:04 PM | #5 |
Racecar Driver
1323
Rep 2,003
Drives: BMW M4
Bimmercode allows you to code the car's features. Bimmerlink allows you to read CELs.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
hC1001610.00 |
03-09-2023, 02:13 PM | #6 |
Rep 277
I had this issue and mine was a rear wheel sensor.
https://f80.bimmerpost.com/forums/sh....php?t=1995813 |
03-09-2023, 03:46 PM | #7 |
Rep 1,015
03-17-2023, 09:51 AM | #9 |
Rep 10
So I finally got the adaptor and ran the bimmerlink app, this is everything I was able to capture...
03-17-2023, 09:55 AM | #10 |
Rep 10
When I look up error 1801 and error 1800 they both show wheel sensor front and wheel sensor rear on the fault code look up. But the 1BD702 says wheel sensor front?
03-21-2023, 08:44 PM | #12 | |
Rep 636
Can you name the shop so other members don't fall for their scams? 1) Ask for a complete refund on the racechip. Flash back to stock and remove. Buy BM3 and use their OTS tunes or get a custom tune. 2) Buy NGK plugs from FCPEuro, gap them to .022. They are free replacements for life. Also an incredibly easy job, takes 2 hours max. 3) given their lack of knowledge I wouldn't be surprised if they forgot to connect something back in. I'd do a thorough search for anything weird. 1k for spark plugs and dp install wow... |
