03-24-2023, 01:20 PM | #1 |
Rep 17
Fan after shutdown
Hi All,
Over the last week Ive heard always the engine fan after shutdown. First I thought it wasn’t normal, but then I figured at this forum that it was normal. Now since today, I realised it is not going on after engine shutdown. As I have warrenty and going for some liquid changes next week, so far not worried. However, wondering if anybody has ideas? I heard it when the outside air temperature was arouns 0 degrees celcius, now the outside air temperature is about 10 daily. Can this have something to do with it? Add: its about 2018, X5M, S63. Edit; After some highway driving, it turned on when I parked it back. But as soon as I started it again, let it run Idle for 4 minutes and shut it down again, it didnt go on. I had the feeling that previously it also went on, even if It runner Idle for 2/3 minutes without driving, but maybe I am wrong. Last edited by Wesley; 03-24-2023 at 02:40 PM.. |
03-24-2023, 03:07 PM | #2 |
Rep 95
What you are experiencing is normal. It wont always run following engine shutdown if temperatures are not high enough. Lots of details here https://f15.bimmerpost.com/forums/sh...&highlight=fan
03-30-2023, 09:11 AM | #3 |
Rep 1,042
Drives: BMW X5M, M3 ZCP, MB E63 AMG
Understand the fans and pumps run to cool down the engine and the turbos. The turbos are cooled by engine oil and engine coolant that circulates thru them to cool down the input shaft that connects the inlet and exhaust turbine blades. Your vehicle has temp sensors and depending high hot will trigger the pumps and fans. A little jolt around the block, will not trigger the fans to kick on. As the outside temps rise, you will encounter this more, than in the cold.
It is never taken for granted that a commitment to speed and acceleration must be matched with an equivalent ambition when it comes time to stop!
