04-01-2023, 12:15 AM | #1 |
Rep 67
Throttle software changes between 2015 and 2017 models?
I am considering purchasing an F82 M4 and have had the opportunity to test drive both a 2015 and 2017 model. During these test drives, I noticed that the 2017 version seemed smoother with reduced wheel spin during acceleration. I recall reading about BMW implementing software updates for power delivery improvements after 2015. Can anyone provide further details regarding these updates? Also, would it be possible for a dealer to upgrade the software on a 2015 model to match the performance of a 2017 version?
04-01-2023, 05:51 AM | #2 |
Rep 228
I think I recall reading that 2015 models were tuned to have more torque in lower gear RPMs than later models. This is why they have more wheel spin. I am not sure if you can upgrade to later OEM programming though. Worth asking one of the folks who offer coding services.
2017 M3 ZCP
Mineral Grey/Black DCT |
04-01-2023, 08:47 AM | #3 |
Rep 696
Drives: 2015 f80 M3
Howdy,
I will back slowturbo on this. When I got my 2015 F80, through research here, I discovered there were incremental changes for the factory tune. When I flashed to the GTS+ tune, the car was way smoother and much easier to daily around. Same with the GTS DCT and diff tune. The original tune was just a bit "raw" IMO. Especially if it is a daily. It is easy to remedy with a flash tune or having the dealer update to the latest OEM tune. good luck either way! josh |
04-01-2023, 09:22 AM | #4 | |
Rep 353
Josh did you need to update your I-step to get the GTS tunes? I’ve considered doing the same to my 2015, but curious how many hoops I’d have to jump through. |
04-01-2023, 09:59 AM | #5 |
Rep 696
Drives: 2015 f80 M3
No, I did not.
It is a pretty long provess. Like a couple hours if I remember correctly. I got what I wanted out the BM3 tune, so I don't intend to update the I-step anytime soon. If you are trying to stay stock, then I would get the update. I will assume the 15 is a more desirable build. Keep in the mind the 15's are the least updatable year for a multitude of things other than the tune of the car. Thay suffer from the sunsetting of 3g and there is no work around other than aftgermarket or costly addons. Just thinking out loud, but I recommend 2017 or newer F82's if you have the patience... josh |
04-01-2023, 01:47 PM | #6 | |
Rep 67
Can you expand on this please? What do you mean "least updatable" and what "multitude of other things"? Thank you! |
04-01-2023, 08:27 PM | #8 |
Rep 696
Drives: 2015 f80 M3
^This.
As well as Idrive was updated signifigantly in 2016. There may be other things, but I cannot recall at the moment. There are a bunch of smarter than me folks around here, hopefully theyh will chime in as well. josh |
04-04-2023, 01:43 PM | #9 |
Rep 67
If the dealer can update the software on the vehicle to a newer version, can the dealer also update the Base software to the Comp package software? Are any dealers willing to do that?
04-04-2023, 02:05 PM | #10 |
///M Powered for Life
11517
Rep 10,345
No. No one is able to do that as far as I'm concerned, including coders. But you can get a 'stage 0' tune which is the CS or GTS map from BM3 and is pretty much the same thing.
04-06-2023, 12:40 PM | #11 |
Rep 81
Not sure how relevant this is, but I've noticed that most (if not all) base cars sound very different - much quieter - when doing stationary revs. Whereas ZCP cars (or even later base models) have more raspy, aggressive notes, 2015s with the same setups seem to have an exhaust note that tapers off in sound at the high end.
As for the torque curve, I can't launch my ST2 2015 M4 for my life even on 295/35 PS4S. In fact I've roasted tires through 6th gear WOT. The later models definitely had some kind of revision. |
