04-06-2023, 02:45 PM | #1 |
Rep 464
Car Jerks and Lose Traction When Shifting at High RPM
Hi Guys,
I'm noticing this issue with my car when I shift above 6000 RPM the car rear wheel will jerk and traction light flash for couple times. This only happens in manual shift 3rd setting, but it doesn't do it when it shifts itself. is this normal? Why is this happening? I'm on BM3 stage 1 93. I don't think this was happening before I tuned the car, is it because too much torque? But why only in manual mode?
Current car: 2016 M4 DCT/Competition Pack/Executive Pack/Lighting Pack
Previous car: 2017 440i 6MT M-sport/Track Handling/MPPSK/CTS Turbo catted downpipe/BM3 stage 2 |
04-06-2023, 03:11 PM | #2 | |
Rep 1,015
Since you have traction control on, maybe thats whats causing your issue. Have you tried turning it off? It could also be something in the tune as well. Maybe the mapping might make the engine do something that upsets it. I really dunno but wanted to let you know you are not alone. |
04-06-2023, 03:28 PM | #4 |
Rep 3,662
how are your tires and what are the outside temps?
warm weather and ps4s i had zero issues in the 2-3 shift.
2018 Porsche GT3 6MT 2021 M2C DCT Previous: Ferrari 458 | R35 GTR | F80 M3 | E46 M3 | E36 M3 | Scion FRS |
04-06-2023, 05:40 PM | #5 |
Rep 464
I have everyhing in sport plus and traction in MDM.
when if only sport and shift bar 2 it doesnt do this. I have DWS06+ all season now but I had PSS before and it did the same. I will have to try turning traction control off to see if that gets rid of it.
04-07-2023, 11:57 AM | #6 |
Rep 468
Sounds like wheel spin from the added power. The manual shifts are seemingly more abrupt which may cause the tires to chirp.
Stickier tires may be the solution. When I bought my car it came with all seasons and they were the first thing I changed.
10 E90 M3 /// Dinan Intake, X Pipe, Exhaust, Underdrive, 3.62 Diff, Coilovers, Alpine e85 Tune - sold
16 F80 M3 /// MaxPSI 4 Pin, DP, CP, SL Mid-Pipe, TMIC, KW HAS, EU5's, AB Performance Flex Tuned |
04-07-2023, 06:50 PM | #7 |
Rep 2,370
Drives: G87 M2; E92M3 MT&DCT; M3 euro
DCT adds forward inertia during a power upshift because the gear changes are so quick, causing the rear tires to momentarily slip. However, this only happens in a straight line because DME controls the ferocity of the shifts depending on the g-sensor inputs so you do not lose traction during cornering. Basically, it's the becauseracecar characteristic.
Pass me if you can.
04-07-2023, 10:15 PM | #8 |
Rep 3
I would recommend opening the config option on the bm3 tune screen and setting torque reduction in 1st and 2nd gear. Personally I set mine to 20% in 1st and 10% in 2nd. Seemed to help keep the back end straight and reduced wheel spin/mdm intervention down.
04-08-2023, 12:14 AM | #9 | |
Rep 3,730
Car is cutting power on upshift due to loss of traction. Wider 200TW tires and warmer weather will help.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
04-08-2023, 01:12 AM | #10 |
Rep 1,225
Nothing is wrong with your car. Also, why are you driving around in sport + on the street? The car won’t like it. Sport + settings are tuned for aggressive driving on a race track.
04-11-2023, 07:44 AM | #11 |
Rep 4,139
04-12-2023, 12:39 PM | #12 |
Rep 124
I've been driving in Sports+ on the street for years, my car loves it.
2018 F83 ZCP in Mineral White: ///M Performance Exhaust, K&N filter, BM3 Stg1, Spacers, EBC Yellowstuff, GTS/CS EDC Coding, All the carbon goodies
2022 G05 X5 sDrive 40i Carbon Black ///M Sports Package |
