04-27-2023, 03:11 PM | #1 |
Rep 80
Replacement Hardware for Downpipe/Midpipe Flange
I started the process to install an AA EL midpipe. One of the nuts/studs was completely rusted/frozen together and I stripped the nut. I started to cut away the nut, but left it unfinished because I ran out of time. I will take it to a shop to have the nut/stud removed. I read that my situation is not uncommon. Any recommendations on what hardware I should use as replacements? Links would be appreciated.
View post on imgur.com |
04-28-2023, 11:08 AM | #4 |
Rep 5,204
If the stud isn’t wrecked I’d ask your shop to clean the stud threads with a tap&die set. Then get a new set of copper nuts so you can reassemble like original.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
Sephrr288.50 |
