05-11-2023, 01:50 PM | #1 |
Rep 842
PSA: How to Avoid Buying a Big Brake Kit that is Worthless!
Hello Gents,
Lately we've been getting more and more calls and emails with questions about grey market brake kits (those not sold through authorized channels), as well as 'brake kits' consisting of low quality, mismatched, and improperly integrated brake components. People are purchasing these products with the expectation that they will function as well as a legitimate, properly designed brake system, and are extremely upset when they realize they've sunk thousands of dollars into what in many cases amounts to worthless junk. In our latest Essex Blog article/video series, "How to Avoid Buying a Big Brake Kit that is Worthless!", we take a deep dive into some of the common traps to avoid when shopping for an aftermarket brake upgrade. We do so by first highlighting how we bring our AP Racing by Essex Brake Kits to market and subsequently support the buyer. Then we contrast our approach vs. the ways in which some of these sellers are hanging their buyers out to dry. Finally, we have a video produced by one of our customers, demonstrating how he unknowingly fell into one of these traps. We're tired of watching our fellow enthusiasts pour their hard-earned money down the drain, and wanted to produce these assets as a public service announcement to all would-be brake kit buyers. You need to be careful not only about what exactly you are buying, but who you are buying from! As always, thank you for your continued support. How to Avoid Buying a Big Brake Kit that is Worthless! (Part 1)- Article How to Avoid Buying a Big Brake Kit that is Worthless! (Part 2)- Video Which of these caliper adapter brackets would you want on your car when hurtling towards a wall at 150 mph? |
05-13-2023, 10:58 AM | #2 |
Rep 529
Nice thanks for sharing excellent remarks about what kind of aluminum and metals are used. It’s important because some grades of aluminum can only be stretched so far.
Something else to mention. Whether a high-end official part or an aftermarket refurbished caliper set, the overall pedal feel may seem the same or weaker than stock. I have a rebuilt set on my E92, and this is due to not using the proper brake bleed procedures and DSC test plan in ISTA. Simply using the old school technique of having your buddy pump the brake on the E9x M platform is not the way. You must run the ISTA brake bleed procedure and then the DSC Unit reset script. That test plan resets the pedal feel to almost new. It tests the clamping force min/max on your new pads. The amount of force it applies is something you couldn’t do with your buddy. To summarize the ISTA brake bleed vibrates air bubbles out of the DSC unit and DSC test plan resets min/max clamping force. Both cannot be done manually. Here is the way for the DSC test plan: Go to operations > Read out vehicle data > Complete identification Vehicle management, service functions, chassis, and suspensions Traction control, adjustment DSC unit, dsc unit adjustment > display > continue > yes
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
05-13-2023, 01:26 PM | #3 | |
Field Marshal
6735
Rep 1,829
Drives: '08 E92 M3
PS: Does the AP Racing by Essex Road Brake Kit for the E9X M3 fit under the OEM 18 inch wheels? I might be in the market for a front kit soon, and you're not that far up the road from me. https://www.essexparts.com/essex-des...61380mm-bmwE90
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
///M Power-Belgium64686.00 jritt@essex1029.00 |
05-15-2023, 11:52 AM | #4 | |
1963
Rep 1,925
Drives: E92 M3
DrFerry6734.50 |
05-17-2023, 08:59 AM | #5 | |
Rep 842
Here is the wheel fitment chart for that kit: https://www.essexparts.com/storage/w...l_template.pdf Below is a list of confirmed wheel fitments for our CP9660/372mm BBK. Confirmed wheels that fit without a spacer: BMW OEM 18" Wheels BMW OEM ZCP 359M 19 x 9" ET31 BMW OEM 220M 19 x 8.5" ET29 APEX ARC-8 18 x 10" ET25 APEX EC-7 18 x 9.5" ET22 APEX EC-7 18 x 10" ET25 BBS FI 18 x 9.5" ET22 Enkei NT03+M 18 x 10" ET25 OZ Challenge HLT 18 x 10" ET25 Signature Wheel SV503 18 x 10.5” ET22 Titan 7 TS5, TS7, and TR10 18 x 9.5" ET22 Titan 7 TS5, TS7, and TR10 18 x 10" ET25 Titan 7 TS5, TS7, and TR10 18 x 10.5" ET25 Volk Racing TE37 18 x 9.5" ET22 Volk Racing ZE40 18 x 9.5" ET20 Wheels that require spacer: BMW OEM 219M wheels with a 15mm spacer Signature Wheel SV501 18 x 9.5” ET28 (had to add a 7.5mm spacer to clear the spring perch from Öhlins R&T) |
DrFerry6734.50 |
05-17-2023, 12:59 PM | #6 | |
BimmerPost Supporting Vendor
4758
Rep 2,560
DrFerry6734.50 |
Tags |
bbk, brake, brake kit, brembo, conversion, disc, retrofit, rotor |
