05-15-2023, 02:12 PM | #1 |
Rep 15
Front Left CV Axle replacement?
Hello there,
Forgive me if this isn't proper forum posting etiquette. I have a bad front left CV axle that needs to be replaced and BMW is charging me near 6 grand for parts and labor. I am looking at doing the job myself but can't seem to find any DIY reference material. Anyone have any ideas or can point me in the right direction? Thanks in advance! |
05-16-2023, 11:31 AM | #2 |
Rep 667
Sign up an account at Newtis.info and go from there.
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP 2017 540i - MHD2+, VRSF DP, TU Pump |
05-16-2023, 11:47 AM | #3 |
Rep 5,025
Realoem.com is the parts microfiche site. Find the part then price out online. Genuine BMW axles are expensive, and aftermarket are not worth the effort most of the time… just a heads up from my 15 years of wrenching.
Newtis mentioned above are the factory instructions showing how to change the part. I’d consider an Indy for this job. Prolly around $2k+. If you don’t have all the large tools etc. Otherwise go for it! |
05-16-2023, 12:28 PM | #4 | |
Rep 15
May I ask what's wrong with after market axles? I don't drive the X5 that much, really just for hauling the canoe and going up to the mountains for camping/ hikes. Are after market axles just not reliable or just don't last that long? I also plan on trading the X5 toward the end of the year. |
05-16-2023, 01:01 PM | #5 |
Rep 667
Be careful when you're buying aftermarket. Even Autozone and AdvanceAutoParts get them wrong at times. Many of the aftermarket axles are rebuilt units, and there are instances of them using substandard pieces in their build. There are also fitment issues at times. Lastly, if you're heavily tuned and there are no upgradable choices available, then stick with genuine axles for durability. Aftermarket axles can fail miserably because they didn't presume to build them for a tuned car.
Lastly, I'll say that I have good luck on my own aftermarket axle from O-Reiley's, but it took me two purchases to finally get it working well. The first one crapped out after 3 months. Then they almost refused to accept the warranty swap because they claimed something to be wrong with my suspension setup. Granted, yes, I did drop in some Bilstein shocks w/Eibach springs, but I also added adjustable camber control arms to have it aligned correctly. Anyway, it's been a good 6 months of using the passenger side aftermarket CV axle so far and all are good. The driver side outer boot did start slinging grease, so last week I took it out and changed out to a new boot, regreased it, and clamped it down, did my own rebuild. All are well.
05-16-2023, 02:30 PM | #6 |
F15 daddymobile
2362
Rep 3,537
OP, how many miles are on your x5? curious at what milestone we would start to see these go out?
05-16-2023, 06:55 PM | #7 |
Rep 358
It's not an awful job if you have done some wrenching. Not even close to a $6k job - they are either attempting to screw you or there is a big piece missing in your story.
I have described it along the way in my Oil Pan Gasket DIY. Post #117: https://www.bimmerfest.com/threads/b....784620/page-6 This is for an E70, but essentially the same job. Once you get up to step 26, they just pop out for removal. You can see it ready to come out in Photos #18 & #21. Last edited by Tomcat_F15_STL; 05-16-2023 at 07:05 PM.. |
05-16-2023, 07:26 PM | #8 | |
Rep 15
05-16-2023, 07:29 PM | #9 |
Rep 15
160k - A lot of road trips across CONUS and through Canada. Haven't really had many issues either, knock-on-wood. Only things gone wrong were cracked valve cover, HVAC blower motor and now this all relatively simultaneous.
05-16-2023, 07:30 PM | #10 | |
Rep 15
05-16-2023, 08:39 PM | #11 |
Rep 358
Another option may be to pull your axles and have them regreased & rebooted.
As long as they aren’t clunking, and haven’t had the grease completely washed away, they’re probably not actually damaged other than the torn boot. |
05-17-2023, 02:51 AM | #12 | |
Rep 5,025
05-17-2023, 08:40 AM | #13 |
Rep 15
05-17-2023, 09:12 AM | #14 | |
Rep 667
Crazy charges, this is why I do my own work and many of my friends/families come knocking on my door for such type of help.
05-17-2023, 01:57 PM | #15 | |
Rep 15
05-17-2023, 03:01 PM | #16 |
Rep 667
I hear ya, bro. Tough times, tough decisions. Best luck and happy motoring, these X5's aren't bad cars, just need love quite frequently.
05-18-2023, 12:25 AM | #18 | |
Rep 1,038
Go here, https://www.realoem.com punch in your vin or pick mode. and go to front https://www.fcpeuro.com/products/bmw...mm-31607629882 $1,363 https://www.fcpeuro.com/products/bmw...mm-31607629883 $1,363 Or a BMW dealer shop front (this is the first link in google for the P/N. not a recommendation, pick your closes cheapest. https://parts.bmwofsouthatlanta.com/...ly-31607622883 $1,189 |
05-18-2023, 07:34 AM | #19 |
Rep 358
Those boot kits are all that is needed - along with some labor you can count on. Boot Kits on FCPEuro.com |
06-01-2023, 04:57 AM | #20 |
Rep 140
GKN is the oem mfg for BMW on the CV axles. Try to find GKN axles and you can save a lot.
They are out there, not sure what GKN’s part number is Also if you can but just the cv, it is attached to the axle spline by a clip, you could just replace the cv and reuse the axle. Back with my e53, that’s what I did, I pulled both axles and rebooted the back and degreased inspected and rebooted the front cv. They have like 1 inch ball bearings in them. Took me a bunch of time but parts were under $100 for the whole job. |
06-01-2023, 08:19 AM | #21 |
Rep 71
You should definitely contact https://www.raxles.com/ and see if they make anything for the F15. I’ve purchased a driver side axle for my 4th gen 4Runner a few years ago and they were pleasant to deal with and the remanufactured axle was high quality.
