01-19-2009, 12:42 PM | #1 |
Critical Care Anesthesiologist
482
Rep 8,828
Drives: SMB F83
Stock setup vs AC Schnitzer lowering springs
I ordered a set of AC Schnitzer lowering springs from Nick @ JLeviSW and received them on the day that I picked up my M3. That's seriously FAST shipping on their part!
I had an appointment to install the springs today but I had a really bad cold yesterday so I'm feeling like I got ran over by a freight train. Instead, I went downstairs to measure the stock suspenion height as a reference point so that I can compare the drop pre- and post-springs installation. My winter tires / wheels are as follows: Wheels = NEEZ EuroCross 7Model in Hyper Black (19X8.5 / 19X9.5, ET35 all around, with 15mm Rogue Engineering spacers all around) Tires = Bridgestone Blizzak LM-25, Front: 255/35/R19, Rear: 265/35R19 Here's the stock height that I got (measured from the center of the wheel to the top of the fender arch: Front: 15" Rear: 14" My target drop is about 3/4 - 1" in the back and 1" in the front. We'll see what the AC Schnitzer springs do and I'll report back.
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist" |
01-19-2009, 01:30 PM | #2 |
Rep 17,017
Hey Kev,
Glad to hear the springs arrived on time. I hope you feel better soon, I am looking forward to seeing these installed on your car. Try measuring the car before and after to record an accurate change in ride height too. |
01-19-2009, 04:51 PM | #4 |
Rep 1,125
01-22-2009, 03:08 PM | #5 | |
salivator
38
Rep 539
bump for an update
01-22-2009, 04:47 PM | #6 |
482
Rep 8,828
Drives: SMB F83
I got sick and the springs are going in the coming Monday. Will report with results, before / after pics, and objective measurements pre and post drop.
01-23-2009, 06:11 AM | #8 |
482
Rep 8,828
Drives: SMB F83
Eibach made the springs for ACS with the spring rates specified by ACS.
AC Schnitzer doesn't have any manufacturing capabilities as far as I know. Everything is outsourced to OEM manufacturers.
01-26-2009, 07:55 PM | #9 |
482
Rep 8,828
Drives: SMB F83
AC Schnitzer lowering springs installed!
Finally gotten around to install the springs today. The drop is moderate compared to RDSport. I measured the drop immediately after install and here are the measurements:
Front 14" (-1" from stock height of 15") Rear 13.25" (-0.75" from stock height 14") I'm very happy with the results. This is the drop that I have hoped for. I'll let the springs settle for 2 weeks and then remeasure them. The handling has not suffered one bit with these springs. EDC is still working in sync with the new springs. No error codes. Here're some pics of the new stance:
01-26-2009, 09:09 PM | #10 |
Rep 8,033
Looks nice, but you are now constantly riding on the front bumpstops as the front suspension appearently has 0.7" travel or so of travel before contacting them.
01-26-2009, 09:11 PM | #11 |
482
Rep 8,828
Drives: SMB F83
I inquired about that and AC Schnitzer in Aachen does not think it's a problem. I guess we'll see how these hold up in the long run.
01-26-2009, 09:19 PM | #12 |
Rep 8,033
I don't think you'll see anything fail or anything. It's just a matter of change the combined stiffness of the suspension without modifying the damper settings, and it the change is significant enough to result in sub-optimal handling. Anyway, enjoy springs and let us know how things go, especially if you make it to the track. Where did you have them installed? (You are in Boston, right?)
01-26-2009, 09:22 PM | #13 | |
482
Rep 8,828
Drives: SMB F83
01-26-2009, 09:49 PM | #14 |
Rep 8,033
Thanks for the reference. Maybe I'll see you at NHMS this spring if you make it there...
01-26-2009, 10:08 PM | #15 |
482
Rep 8,828
Drives: SMB F83
Hopefully, I'm still a novice, so I'll probably have the founder of BPG to teach me a thing or two. He's a licensed track instructor.
01-26-2009, 10:37 PM | #16 |
Rep 8,033
The BMW CCA guys are pretty friendly in general, and that would be a safe start--don't know if your friend instructs with them. The track is a bit too tight though with not a whole lot of run-off areas and so on. It's still a lot of fun. I run in the high-intermediate group, so I have much to learn as well.
01-27-2009, 07:56 AM | #20 |
Rep 8,033
it's more like "lucid questioning if constantly riding on bumstops without messing with the shocks is a good idea". anyway, i don't want to jack this thread. and it sure looks good.
02-05-2009, 07:56 PM | #22 |
482
Rep 8,828
Drives: SMB F83
I think the ride actually got a little harsher. EDC off is not as cushy as before, but I'm not too worried. I looked at the ride height today and it seems to have settled a bit more. I'll take some measurements tomorrow to see if there's any change in ride height.
