06-08-2023, 10:44 AM | #1 |
Rep 19
F82 Dedicated track car build
Hi,
I have gained so much insight and information from this forum, I thought it was only right I share my build with everyone. Before starting this build I had little to no knowledge about cars but last year I started to track my McLaren 720s regularly, this was starting to get very expensive with consumables hence why I decided to build this 720s/GT3 killer. The car is still road legal but I have a trailer and the car will eventually be a none road legal dedicated track car. In its current form the car handles very well and performs great on track. A little more power would be good. Base car 2014 F82 with 35K miles Current Mods Engine: VTT Crank hub upgrade and Crankshaft Bolt Capture Kit EcuTek Custom map with map switching and push to pass The Turbo Engineers TTE740+ Turbo upgrade Wagner Charge Cooler Wagner Front Mounted Intercooler Wagner Side Mounted Intercooler MishiMoto Oil Cooler Kit (Including Braided lines) Mishimoto BMW S55 M2 M3 M4 DCT Oil Cooler VRSF High Flow Single Mid-pipe Upgrade for 2015 – 2019 BMW M3 & M4 F80/F82 S55 Akrapovic Catless Downpipes DP-BM/SS/3 MMR Performance Charge Pipe Kit MMR02-1001 MMR Replacement Panel Air Filter Airtech motorsport catch can M4 Oil Overfill Kit - Level Sensor and Spacer Kit Suspension/Wheels/Brakes/Drivetrain: KW V3s Clubsport Milway camber plates Front adjustable drop links 2Forge ZF6 18x11 Front:ET25 Rear:ET44 Nankang 315/30/18 AR1 Tyres Wheel stud and nut conversion AP racing PRO 5000R 6 pot front (Rears on back order) Draxler LSD (Coming soon) Team Schirmer differential lift kit Interior: Recaro SPG driver and passenger TRS 6 point harnesses Club sport half cage Rear seat delete kit Exterior: Big wing, unknown brand purchased used. GTS Spoiler lip Next up: AP motorsport GT4 front splitter (To balance the aero as the rear wing overpowers the small GTS front splitter) varis diffuser + undertray (awaiting delivery) Canards Lightweight panels Lightweight windows KMP steering wheel Full FIA weld in cage Further stripping of the interior to reduce the weight If anyone can provide any feedback or suggest improvements for the build it would be greatly appreciated. As I said above my knowledge of cars is low and everything I have learned has been from this forum mostly. If I can help anyone or answer any questions I would be happy to. Last edited by johnjames85; 07-01-2023 at 12:38 PM.. |
06-09-2023, 09:23 AM | #3 |
Rep 715
love to follow and learn from track builds, looking forward to following the journey...
2015 M3 - GT4 replica Ongoing build thread https://f80.bimmerpost.com/forums/sh....php?t=1802471 For Pics / Video's visit Instagram https://www.instagram.com/ninekrpm1/ |
06-09-2023, 10:16 AM | #4 |
Rep 88
Drives: BMW M4CS
Very nice build coming together!
06-09-2023, 10:29 AM | #5 |
Rep 507
Drives: M4 GTS
I’d drop an AIM MXS dash for logging and more car insights.
The F Protocol gives tons of info and configuration potential. |
FrankMstein1039.50 |
06-09-2023, 02:41 PM | #7 |
Rep 19
06-09-2023, 03:37 PM | #8 | |
Rep 507
Drives: M4 GTS
The bracket is custom yes. I SCOURED the web for a solution and couldn’t find anyone. From Schmickler to Lang and everyone across the board. Nothing ready to go so custom it is. This one is temporary for now, I have a guy in the mid west that is going to 3D print the upper steering column cover to house the dash as a single piece. He doesn’t it for other spec chassis. PM me if you want it on that. |
06-09-2023, 04:03 PM | #9 |
Rep 46
Did you swap springs in your clubsports? I have front clearance issues with mine. I also think the front springs might be a little too soft
Nice build, 315 front is crazy!. |
06-09-2023, 06:47 PM | #10 |
Rep 19
I definitly want in on that. Count me in.
The garage that have completed most of the work suggested a universal carbon motorsport dash. Looking into that as a much cheaper option to the GT4 dash. Last edited by johnjames85; 06-09-2023 at 07:42 PM.. |
06-09-2023, 06:50 PM | #11 |
Rep 19
No, they are out the box no changes to the springs. The garage that worked on the car said they had to remove some of the trim inside the wheel arch. Please excuse my lack of knowledge and terminology, this is all new to me.
I have not noticed any clearance issues and this car is still on the road. Once I get the GT4 front splitter with break cooling I will install the BimmerWorld Steering Rack Stops. As from my research I will definitely have clearance issues once the break cooling is installed. Last edited by johnjames85; 06-09-2023 at 06:55 PM.. |
GreenGoblin51.50 |
06-21-2023, 04:36 PM | #12 |
Rep 163
With hybrid turbos and cat-less down-pipes be prepared for black flags caused by noise, especially at Brands. You may get away with keeping the rest of the exhaust standard.
I’ve been developing a valve-less 3” exhaust with 200 cell sport cats to get around this issue on my own car. Forget Akrapovic and Remus full system pipes, you’ll never see a track again unless it’s a very rare unlimited day. It’ll make your 720s sound quiet. |
06-22-2023, 09:37 AM | #13 |
Rep 163
Just looking at your list again. I also went with Varis with my E92 but wish I hadn’t. It’s purely cosmetic and not at all functional. In fact the diffuser will slow you down by ballooning with air between it and the floor pan at speed. Functional diffusers I don’t think are possible off the shelf for bolt-on applications.
06-29-2023, 03:11 PM | #14 | |
Rep 19
This is a big worry for me as my local track and the one I frequent the most is Brands hatch I had hoped/prayed that keeping the backbox stock would be ok. If not I will have some catless downpipes for sale in the future. Thanks for the heads up. |
peter de la mare126.00 |
06-29-2023, 03:14 PM | #15 | |
Rep 19
