06-09-2023, 03:52 PM | #1 |
Rep 4
What Year Rims Fit/Replace 21" 17 X6M?
Hello, I am new to BMW and just purchased a 2017 X6M for my wife. We are looking for another set of OEM rims. What year(s) will fit this model? I see many X6, X5, M and M Sport OEM take offs for sale locally from different years, but I do not want to buy if they won't fit. I am looking for 21" to replace the 21" we have now. I plan to turn the current set into winter rims. Thank you
06-09-2023, 04:09 PM | #2 |
F15 daddymobile
2358
Rep 3,535
if youre after a dedicated winter set, i'd consider jumping down to the 20" 611 wheels or 20" 469s. Use those as your winter set and you'll have a ton of tire options in that size. i personally run Michelin Alpins and love them. They've done well for our ski trips to the mountain.
06-10-2023, 11:18 AM | #4 |
Rep 1,340
I just listed a set of OEM 21” 612m set from my 2017 X5m. This would be a direct bolt-on for your X6m.
https://f15.bimmerpost.com/forums/sh....php?t=2024541 |
06-12-2023, 10:09 AM | #6 |
Rep 7,588
Any F15/F/16 F85/F86 wheels will fit...and have the same wheel bolt pattern (5x120), hub size (74.1mm) and offset range.
The e70 X5 also has the same wheel bolt/hub size/offset range. If the offset varies too much, you may need wheel spacers...so check the wheel's offset & compare it to your original wheels to verify there won't be too much "inset" (toward the suspension) or "poke" (toward the fender). Wheels to avoid:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
