06-26-2023, 11:09 AM | #1 |
2018 F15 X5 X40d #BSM #IvoryWhite
40
Rep 334
Front Brake Pads iDrive Mileage Question - Odd behaviour, any suggestions?
Hi all,
I have a 2018 F15 X5 X40d and I'm the first owner. Firstly, I just want to say I've read a lot of the existing threads and watched YouTube Videos. I've also done my own coding in the past so I'm not a complete novice. I'll try to keep this brief:
Is there any way to reset the countdown mileage on the front pads to make it more in line with the rear pads i.e. 14,000 miles? Or, does it sound like a faulty sensor for the front pads? Somewhere else I read that 14,000 to 3,200 miles is just an arbitrary countdown and then it pauses the countdown at this milestone until the sensor is actually triggered then it begins counting down again? Any insight would be really useful! UPDATE: I took the car to my local BMW Main Dealer today and they've booked it in the workshop for Tuesday 4th July to have the service technicians have a look at it for free! So let's see what they come up with...I'll keep you all updated Last edited by ibz.s.b; 06-27-2023 at 09:53 AM.. |
06-26-2023, 01:59 PM | #2 |
Rep 7,590
You’re probably going to need to hook up to diagnostic equipment at this point to do a reset to get a better result of approximate mileage. You should have taken the dealership’s offer (if it was free).
There is something designed into the cluster reset procedure to prevent owners with “too-early-reset syndrome”. There is a minimum requirement that must be met on some service resets.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
06-26-2023, 04:29 PM | #3 | |
40
Rep 334
Thanks for the reply. The last sentence in the section you haven't highlighted might be my issue? Since no sensor has physically been replaced since September 2022 when the pads were actually done then perhaps for the Brake Pads to be reset successfully either the sensor needs to be plugged out and back in, or replaced entirely? |
06-26-2023, 06:24 PM | #5 |
40
Rep 334
06-26-2023, 08:38 PM | #6 |
Rep 672
I’d check that front pad wear sensor. It sounds suspect. There isn’t much too them and can get damaged and trigger the service light.
Easy to check and replace for DIY’er. |
06-27-2023, 10:38 AM | #7 |
Rep 2,529
