06-30-2023, 05:49 PM | #1 |
Rep 5
Rear of car dropped and very bouncy after aggressive acceleration
I've searched for this issue but can't find a similar scenario. I have an 2017 F85 with 55K miles and two days ago I was merging onto the highway and accelerated aggressively (30 to ~100) and got a Chassis Function Restricted almost immediately and the rear of the car became very bouncy.
When I parked the car, the rear is sagging on both sides and won't raise after car's parked for a few days. I was going to remove the rear tires this weekend and take a look, but I figured I'd ask for advice on where to focus. My guess is that there are sensors that are damaged? Thanks for any suggestions! |
07-01-2023, 07:10 AM | #3 |
Rep 1,040
Drives: BMW X5M, M3 ZCP, MB E63 AMG
If your vehicle is sagging in the rear, the likely culprit is worn out rear air bags. They aren't very expensive to replace. The issue is that they're made a rubber and as rubber ages, they develop tiny cracks, which allows the air to escape.
It is never taken for granted that a commitment to speed and acceleration must be matched with an equivalent ambition when it comes time to stop!
07-01-2023, 06:25 PM | #4 |
Rep 5
Thank you for replying guys.. I removed the rear tires and my air springs were completely deflated on both sides. The height sensors seemed to be connected properly and not broken. I also checked the fuses and relay and they were fine.
I then removed the air compressor and dismantled it. I followed a YouTube guide on renewing the compressor. After reinstalling it, the rear air springs have re-inflated and the car runs smoothly again. After seeing the advice here and on this forum, I will replace the air springs anyway. At least now, I can drive the car to work while I wait for the parts to come in. Turns out, I have to replace the rear brake pads anyways ☺️😃 Thank again guys! Edit: *deep, disappointed sigh* I just saw I left out an O-ring.. will need to remove the compressor again 😞 Last edited by zoh721; 07-01-2023 at 06:51 PM.. |
07-02-2023, 10:31 AM | #5 |
Rep 592
Drives: 2018 X5M , 14%E2%80%99640i ver
Before you drop bucks on new bags, as you are obviously a wrencher…..get under car with spay bottle with water and Dawn…shake up and spray ….watch for bubbles. If leaks apparent replace…if not wait for bag failure. I had one go at about 50k, the other is still going strong
