07-02-2023, 08:10 AM | #1 |
Rep 53
08’ E92 6MT Car Won’t Go Into Gear - Burning Smell
Hello,
For the last few drives I’ve been feeling like my clutch is not engaging/grabbing like it normally does. I have a stage 2 evolve tune. I would press the pedal and then it would rev up and slowly engage into gear. Today I was pushing it and I smelt a burning smell on the highway and then it wouldn’t engaged at all with the gas pedal pressed. I’m on the side of the hwy now waiting for the tow. The clutch pedal was fully pressed in when I pulled over The car does turn on when the clutch is pressed and it does not turn on when clutch is not pressed so that is normal. When I move the gear shift into gears nothing happens whether clutch is pressed or not. Any idea what the issue could be? I do think this started a few weeks ago when I did an aggressive pull out of first. Which I never normally do but did that time for some reason and I smelt the same smell I smell now. Thank you in advance! |
07-02-2023, 10:01 AM | #2 |
Rep 7
Clutch itself is bad or the clutch slave or master is dead.
Assimilator1595.50 |
07-03-2023, 05:53 AM | #4 |
mTekMods
2169
Rep 2,922
the burning smell would be a sign of a hardware issue relating to the clutch, hydraulics would not make the clutch slip.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
07-03-2023, 02:33 PM | #6 |
Rep 53
Thank you! The mechanic confirmed that it is the clutch. 180k miles. I’ve been hearing about the flywheel being update to 09+ so I’ll anticipate having that updated as well.
07-04-2023, 01:50 AM | #7 |
Rep 1,138
Drives: 2009 E92 M3 Dakar Yellow II
If you think your clutch is on it's way out but are not sure, take your car to an empty parking lot. Keep the car at idle and keep your right foot on the brake. Clutch in and engage 5th or 6th gear and slowly let the clutch out noting what happens to the rpm as the clutch runs out of pedal throw. If you can make it most of the way to the top of the pedal range before the engine stalls or rpms nose dive, you know the clutch is fuct. If it never stalls, well you know how that feels by now, it feels like a tow truck ride.
07-07-2023, 10:57 AM | #8 | |
Rep 53
