Go Back   6Post.com | BMW 6-Series Forum > BMW 6 Series Forum > BMW M6 Forum (F12 / F13)
      07-07-2023, 10:41 AM   #1
NGROSSO
Drives: 2017 Alpina B6 -- 2016 M6
Help with Alignment specs?
Hi Guys,
Anyone know the alignment specs for an f06 m6? If not, know where to find them?
Thanks,
Nick
      07-07-2023, 04:55 PM   #2
Opie55
Drives: '15 650i Convertible
Here you go
Observe test conditions!
Front axle:
Total toe-in 0° 10' ± 12’
Total toe-in adjustment* 0° 10' ± 4'
Toe difference** single wheel between left/ right max. 12'
Camber
(difference between left/right max. 30')
- 0°29' ± 30’
Camber adjustment* ‐ 0° 29' ± 25’
Toe difference angle (difference between left/right max. 30') ‐ 1° 51'
Castor angle (difference between left/right max. 30')
Front wheel offset 0° ± 15'
Maximum steering angle
‐ Inner cornering wheel Ca. ° 42° 14'
‐ Outer cornering wheel Ca. ° 33° 00'
Rear axle:
Total toe-in 0° 18' ± 12'
Total toe-in adjustment* 0° 18' ± 4'
Camber (difference between left/right max. 30') -1° 50' ± 25'
Camber adjustment* -1° 50' ± 5'
Geometrical driving axis 0° ± 12'
*Note: To minimise adjusting errors (measuring inaccuracies), use a narrower tolerance for adjusting toe/camber.
**Note: Toe difference front axle = criterion for steering wheel inclination
      07-07-2023, 04:58 PM   #3
Opie55
This say for "Standard Suspension." I'm not sure what that means on an M6.
32 00 Wheel Alignment F06 / M6 Standard suspension
Front axle:
Camber
(Difference between left/right maximum 30')
- 0° 55' ± 30’
Camber adjustment* - 0° 55' ± 25’
Toe difference angle (difference between left/right max. 30’) - 2° 42'
‐ Inner cornering wheel Ca. ° 40° 12'
‐ Outer cornering wheel Ca. ° 32° 06'
Rear axle:
Camber (difference between left/right max. 30') -1° 40' ± 25'
Camber adjustment* -1° 40' ± 5'
      07-07-2023, 05:00 PM   #4
Opie55
Here is F06 M6 Comp. I think the first one I sent was just for the F06.
32 00 Wheel Alignment F06 / M6 Competition package (sports suspension settings, not low-slung)
Front axle:
Camber
- 0° 55' ± 30’
Rear axle:
6post.com
