07-11-2023, 01:24 AM | #1 |
J
382
Rep 712
Drives: BMW 128i
Non M-Sport Rear Sway Bar install frustration - Help
Basically as the title states, I'm having frustration with this rear sway bar install.
Car is non-m-sport so I ordered the complete kit from FCP. I was able to snake the sway bar in. Now I'm trying to install the brackets but the bolts won't thread. They just kind of spin. It feels like there is some threading in there, but I can't tell. I'm getting no purchase when I spin the bolt. The nose of the bolts is long before the threading starts. I feel like maybe that's the issue? Part numbers match up. The pic is of a brand new bolt. Comes out with a little rust and I'm worried that it also looks like the thread is being damaged. Any advice here? I know this has been done before. I couldn't find what I was looking for through search. Peace. |
07-11-2023, 06:01 AM | #2 |
Rep 473
Drives: 11 128i 6MT Sport
Can you thread the bolt in by itself without the bracket? Or can't even do that?
Also, measure the diameter of the bolt and make sure it's 8mm.
11 128i slicktop
13 WK2 19 Alltrack S |
Blau381.50 |
07-11-2023, 10:37 AM | #4 |
J
382
Rep 712
Drives: BMW 128i
07-11-2023, 10:42 AM | #5 |
J
382
Rep 712
Drives: BMW 128i
Likely my next move, but if I have to completely drop the subframe off of the car to make the tap fit I'm just going to pass on installing it. I've gone far enough with the rear of this car. Maybe if I end up getting an LSD at some point I'll do it then.
Thanks for the tip. |
07-12-2023, 05:52 AM | #6 |
Rep 473
Oh good call on cleaning up the threads. Don't know if you've seen these before but I picked up this set years ago and it's been awesome for cleaning up threads in random places around the cars.
The chasers are small enough that they fit just about anywhere and they have a 13mm hex on them so you can use a wrench/socket to turn them. https://www.amazon.com/Lang-Tools-25.../dp/B000XJ48V0
11 128i slicktop
cerealwars87.00 Blau381.50 |
07-12-2023, 04:16 PM | #7 | |
Rep 2,806
If I recall, I dropped the subframe a bit without really removing any of the bolts. Just enough to get the bar in. If you want to drop the subframe a lot, you can separate the brake lines without losing much fluid by putting something in between the seat and brake pedal to hold the pedal about 2/3 way down.
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
07-13-2023, 12:14 AM | #8 | |
Rep 45
Then, while I was on a roll and had the tap and die set out, I removed all the wheels studs and cleaned them up too. I was surprised how much easier it was to remove and replace the wheels after that! |
Blau381.50 cerealwars87.00 |
07-13-2023, 10:16 AM | #9 |
J
382
Rep 712
Drives: BMW 128i
I was able to squeeze a tap in and get the bolts started. I ham fisted one of them in and then decided I needed to wait for a shorter tap so I could do a better job. It'll be here in Saturday.
I'm glad I didn't bail on this project. It's fun y because this installing this sway bar is 100% harder than doing all 7 subframe/ diff bushings. Snaking that sway bar through those right clearances was super frustrating. Might have been easier with a helper. |
cerealwars87.00 |
