BMW X5 and X6 Forum 2014-Current
      07-12-2023, 05:56 PM   #1
chadilax
Drives: BMW X5 F15
Clunk when backup after going forward and braking
Notice this consistantly when coming home. I pull past my drive and stop, then backup into the driveway. When reversing and then applying brake pressure, I then hear a clunk. I can get it to repeat just about every time if I first drive foward at a decent speed and brake.
So my thought is a loose brake caliper. But I double checked them all and they are all tight.
Any other ideas?
I did recently replace tie rods, brakes, rotors, front suspension, rear shocks.
      07-12-2023, 07:37 PM   #2
jbfrancis3
Drives: F15 35d
Did you put wrenches on the bolts to verify tightness?
I had a loosening front lower inner control arm (aka lower wishbone per TIS) bushing. It was aftermarket and since removed. But it was causing a clunk as you describe. The nut should be torqued to 165 Nm for reference (tightened in normal position)
      07-13-2023, 12:25 PM   #3
chadilax
Drives: BMW X5 F15
Yes, but maybe I'll check the control arm bolts as well. Thanks for your insights!
      07-13-2023, 03:43 PM   #4
RED_Y_
Drives: 2014 X5 3.5d
Some brake pads can cause this sound.
xbimmers
