07-14-2023, 09:31 AM | #1 |
Rep 48
Fuel injectors X5M/X6M
Have been looking to replace the fuel injectors on my ride. Looking at realoem.com there are two options being referred to, EU6 and EU5, and some mention of determination function. I am guessing this is something ISTA does to determine which injector types the vehicle has?
Anyway, my question is do I need to install OEM injectors from BMW, or are Bosch injectors just as good to run with? Bosch injectors seem to be a fraction of the price. Cheers. |
07-17-2023, 03:25 AM | #3 |
Rep 48
07-25-2023, 02:12 PM | #4 |
Cattlecar
Rep 141
If you have a flex probe inspection camera you can see the Bosch numbers on the injectors without removing anything. FCP euro and another site had info with the part numbers that were the two injector versions. That will leave with zero doubts. The numbers are on the black plastic body of injector and you can move camera tip around and get a position where you can see them. My recollection was that the numbers were at 4 or 7 o'clock as look down around the injector body.
08-13-2023, 04:05 PM | #5 | |
Rep 48
