07-14-2023, 09:36 AM | #1 |
Rep 95
Power Steering & Dynamic Drive Fluid
This week I changed the last remaining fluid for my 50k service: the power steering and dynamic drive fluid.
There is no official service interval for this nor have I heard of anyone on this platform changing it but it was the "last fluid standing" so I had to do something about it! I read and watched videos of others draining via disconnecting the hose from the cooler. Instead, I ended up using a fluid extractor to remove ~1L of fluid from the reservoir, refilled, drove a few hundred miles, and did it again. The fluid once black is now dark green. I used two cans of Pentosin 1405116 CHF 11S Long-Life Synthetic Hydraulic Fluid. |
07-14-2023, 05:09 PM | #2 |
Rep 1,042
Drives: BMW X5M, M3 ZCP, MB E63 AMG
I change the power steering fluid every two years. What do you mean by dynamic drive fluids, are you referring to the intercooler charge fluid? If that's it, I change it every 4 years along with the engine coolant.
It is never taken for granted that a commitment to speed and acceleration must be matched with an equivalent ambition when it comes time to stop!
07-17-2023, 08:32 AM | #3 | |
Rep 95
What is your method to change this fluid? Curious. Last edited by zeroping; 07-17-2023 at 10:07 AM.. |
07-17-2023, 09:03 AM | #4 |
Rep 1,042
You can use either a suction fluid extractor, or loosen the lines to the rack and dampers. I prefer to use the suction extractor, becuase loosening and tightening of lines will leak over time. When sucking out the fluid in the rack you do need to turn the wheel lock to lock to suck out as much fluid as possible. And I only use synthetic fluids .
zeroping41.00 |
07-17-2023, 10:07 AM | #5 | |
Rep 95
07-17-2023, 12:21 PM | #7 |
Rep 95
