07-17-2023, 08:27 PM | #1 |
Wifey's Vehicle!
Rep 16
Unexpected Messages
This morning the wife went to work.. the cars started up fine and all appeared well.
On the way home, she called and said she was getting notifications that included the following: CC msg: Chassis stabilization: Drive moderately CC msg: Parking Brake: Continuous driving possible Restraint system: Fault in airbag, belt tensioner or belt-force limiter As far as she could tell, it still drove fine. We went ahead and dropped it off at the dealer. Do you think these could be caused by a weak battery (batteries)? There are no records that indicate a battery change and we are the third owner. I don't have a code reader to check the codes. Any ideas? It's just weird that it's been fine all week and then these notifications pop up. |
07-17-2023, 10:09 PM | #2 |
Rep 451
If you look in your trunk, at the top of battery post will be stamped with manufacture date,if battery is original. If your battery is original, it's due for replacement.
07-18-2023, 07:34 AM | #3 |
Wifey's Vehicle!
Rep 16
I found some pics I took of the batteries when we purchased the car in 2021...they're not the greatest, but I'm not able to determine the dates from them. Do y'all see it?
07-18-2023, 08:01 AM | #4 |
Wifey's Vehicle!
Rep 16
Duh..
Did a quick search and found the answer... one of the batteries was manufactured in 2016... the image isn't as clear for the other one, but I'm going to assume it was pretty close. stocktree Thanks for the tip. Last edited by Sounbwoy; 07-18-2023 at 03:52 PM.. |
