07-23-2023, 09:22 AM | #1 |
Rep 625
Drives: E89 Atacama Yellow 35is
A few mods you could do?
My wife often asks me "what are you doing to that car now?" or words to that effect....also a few people have asked me "what mods have you done to your Zed?"
Today was a long wet and windy day..so I thought I'd try and remember some of the things that I've done to this "Yellow Peril" I'm sure I've forgotten a few..maybe an inspiration for you? 1 Zito 935s 235/40 18 265/35 18 Michelin PS4S 2 Front HALO angel eyes LED upgrade 3 Remove silver slats from lower grills 4 Reverse colours on valance and rear diffuser 5 Gloss black Kidney Grills 6 Inlet port walnut blast 7 Mahle air filter 8 Dyno check 347 BHP 505Nm 9 2022 Map upgrade 10 Bluetooth s/w upgrade 11 MHD V9 stage 1+ 390 bhp 560 nm 12 xHP stage 1.2 13 NGK coils 14 NGK 1 stage colder plugs 15 Uprated oil thermostat 16 Redline ester based engine oil and Mahle filter 17 6 pot Brembo BBK front grooved /drilled 18 Uprated anti roll bars front and rear 19 Replacement parking brake motor 20 Engine bay strut tower brace 21 Zimmerman drilled / vented rear discs 22 Colour matched calipers Phoenix Gold 23 Catless down pipes 24 437M alloys with Michelin PS4s 25 Limited Slip Diff 26 MHD V10 stage 2+ 408 BHP 655Nm 27 xHP stage 1.3 28 Uprated HID bulbs 29 Revo boot rack 30 DCT aluminium deep sump 31 DCT oil and filter changes 32 Aluminium oil filter cap 33 Uprated suspension 34 Removal Adaptive ECU plus coding 35 Monoball bearing for front suspension arms 36 Evo 1 Intercooler 37 Z4 and 35is badges deleted 38 M3 E90 RTAB upgrade 39 Gloss black roll over hoops 40 437Ms refurbished in gloss black 41 E90 M3 front Suspension arms 42 Colour matched rear carbon fibre boot spoiler 43 Centre speaker upgrade 44 Door card speaker upgrade and door tweeter 45 Rear shoulder speaker upgrade 46 Rear centre speaker upgrade 47 Rear brake lights LED upgrade 48 Rear reversing lights LED upgrade 49 Pierburg alloy water pump + Mahle Thermostat 50 LCI side repeaters in gloss back 51 Retrimmed and flat bottom steering wheel 52 Later flappy paddles one sided action 53 5mm front wheel spacers 54 Arc 8 19" 8.5j 35 and 9.5J 33 55 Michelin PS4s fitted to Apex arc 8 in satin black 56 Arc 8 refinished in gloss black 57 245/35 19 275/30 19 Sports Contact 7 58 Meyle HD toe rods 59 Index 12 injectors 60 Stage 2+ DME re-map 61 Stage 2 TCU re-map 62 Stage 1 colder plugs 63 B58 Ignition coil kit 64 Uprated steering tie rods 65 Later all metal water pump 66 Adjustable toe and camber plates 67 Adjustable rear camber arms 68 Alignment done 69 New rear boot struts fitted 70 Garmin 57 and Mini 2 dash cams fitted 71 Fox centre and rear exhaust system 72 TTE 500 Hybrid Turbo Upgrade 73 Uprated turbo outflow pipes 74 Uprated turbo inlet pipes 75 Uprated charge pipe 76 Uprated 450 lph LPFP 77 Wagner EVO 3 FMIC 78 Forge diverter valves 79 Uprated GUIBO 80 Uprated centre shaft bearing 81 Tuning for new hybrids 82 Pipercoss panel filter 83 Dyno test day 502 BHP 683Nm 84 Footwell woofer upgrade 85 New boost controller solenoids 86 Carplay adapter 87 Carbon fibre wrapped interior trim pieces 88 Retrimmed gear gaiter 89 Replaced snap in tray with general tray 90 New set of 437Ms 91 437m refurbished and finished in graphite grey 92 235/35 275/30 SC7s fitted to 437m 93 Brembo HP front pads 94 Rear adjustable toe in plates 95 Uprated RTAB and rear linkage bushes 96 New aligment less rear camber better toe 97 LED lights for map reading, boot, puddles 98 New G29 Z4 and M50i badges 99 Refitted turbo oulet pipe silicon hose + heat shield 100 Mr.5 Inlet modification
Much modified 2011 Atacama Yellow 35is…previously a much modified 2012 Atacama Yellow 20i MSport
Change history here… https://www.dropbox.com/s/8h1vabklgz...0List.pdf?dl=0 Build thread here… https://z4-forum.com/forum/viewtopic.php?t=131886 |
07-24-2023, 03:48 AM | #3 |
Rep 625
For other reasons…upcoming audio controller for DSP/amp so needed to change the ash tray from the smokers package…so I took the 12v power socket out of the ash tray and plugged a two port usb charger hub into it and hid it under the centre trim.
Fed the cables round to the two cameras. Disadvantage, if it is, is that it on,y works when the ignition is enabled.
07-24-2023, 10:10 AM | #4 |
Rep 625
07-25-2023, 12:15 PM | #5 |
Rep 121
Thanks. I already pulled power from the center console power other to add USBs that I installed behind the radio v for cell prone charger. I thought perhaps you were able to find some power in the OH console. I'm only installing front dash cam for now so I'll probably tap the same 12v power and run up the A pillar. Just using ignition power for now since I just want can while driving and not while parked.
Thanks |
07-25-2023, 12:17 PM | #6 | |
Rep 625
