      07-02-2007, 12:22 PM   #1
Matt60158
///M
13
Drives:
Transmission question
First, I am new to euro cars so forgive me lack of knowledge.
Curious to learn more about the 6-speed manual trans. bmw plans to employ in the new 1 series. If you could give me a model I would like to reasearch it a bit. I am guessing it is similar if not the same trans. used in other bmw models with the 6-speed. If this is the case does anyone have an idea of how much power can the trans. can handle and how durable is the clutch from the factory?
Matt
      07-03-2007, 12:19 PM   #2
Matt60158
///M
13
Drives:
bump
      05-05-2008, 07:16 PM   #3
kerph32
Drives:
I'm curious too - I read in a review that the 6-speed is actually different than that in the 335i - is that true?
      05-05-2008, 07:24 PM   #4
atr_hugo
No longer moderate
atr_hugo's Avatar
Drives: '13 135i
ZF manual box in the 135i, IIRC same as the ZF in the 335i. Suspect same gear ratios through final drive.
      05-06-2008, 09:27 AM   #5
NewYorkDesigner
Drives:
I felt the difference between the 135 and 335 6-speeds were slightly different. The shift throw is definitely shorter in the 135. The clutch take-up is the same but the clutch travel seemed just a tad shorter in the 135, though I don't know why that would be since this part is identical to the 335.
1addicts
