BMW X5 and X6 Forum 2014-Current
      08-10-2023, 10:55 PM   #1
dentprotony@gmail.com
Drives: 2018 f85
Something every S63/N63 owner should check II
I spent months chasing intermittent off the line hesitation and occasional ‘drivetrain malfunction’ message , very seldom i would get multiple misfire code as well, so finally was able to find an issue, thanks to Jamie Showoff on FB f85 forums for mentioning this to me. Hope this helps someone out there because i was lost and replaced a lot of parts chasing this issue
      08-17-2023, 08:26 AM   #2
zero2sixtyZ
Drives: e92 + f15
Interesting find. Was trying to get a grasp on the part location via diagrams / images. This is the part in question?:
https://www.realoem.com/bmw/enUS/sho...92#11668605976
https://www.fcpeuro.com/products/bmw...mp-11668605976
      08-18-2023, 05:33 AM   #3
Drives: 2018 f85
Yes correct, very easy to access, i had 2 shops give up trying to diagnose the issue. One forum member from Australia suggested this and that was the solution
      12-24-2023, 04:12 PM   #4
blown99
blown99's Avatar
Drives: 18 X6M
Did you buy the Klifex part on Amazon? That’s the one that looks like it might work?
      12-27-2023, 11:30 AM   #5
Bobby_Drake
Bobby_Drake's Avatar
390
Drives: '16 X5M
Did you have any symptoms with your brake?
I have a similar issue where I got the drivetrain malfunction/check engine light and the car lost power. I've just replaced coils/plugs about 3K miles prior so I was confident it wasn't that. However, the hesitation/loss of power felt similar. Then the next day when I connected an OBD II scanner, no error codes and then the DTM/CEL went away and the car drove fine...
Of course I am not at ease knowing something is brewing without any CEL anymore.
      01-17-2024, 08:49 PM   #6
Drives: 2018 f85
When was the last time you serviced your transfer case?
      01-18-2024, 01:34 PM   #7
Bobby_Drake
390
Drives: '16 X5M
Just had it at 52,000 mi. I'm at 58,8XX
      01-20-2024, 09:22 PM   #8
FirstBMWLA
FirstBMWLA's Avatar
188
Drives: 2007 335i Coupe
This has got me thinking.
I've long had occasional symptom where if I came to a 4way stop and barely stopped. Then tried to quickly accelerate there will be noticeable hesitation. No error but acts like I'm not hitting gas briefly.
      01-22-2024, 01:23 AM   #9
Bobby_Drake
390
Drives: '16 X5M
As Tony showed on the video, this is an easy DIY. Due to a recent DTM/CEL, I replaced mine since this can be an issue anyway (although mine was ok @ 58,8XX mi.)
      01-22-2024, 05:35 AM   #10
tfunk88
Drives: F15 X5 50i
Looks like this part is actually available for sale vs buying the entire vacuum pump. And it’s “Not China Valve!” lol
https://www.ebay.com/itm/11504578734...3Avlp_homepage
      01-22-2024, 10:42 AM   #11
shimmy23
F15 daddymobile
shimmy23's Avatar
2358
Drives: GS X5
from Klifex which would be the same as the amazon?
      01-22-2024, 10:59 AM   #12
tfunk88
Drives: F15 X5 50i
Appears to be the case
Amazon says a few days shipping, eBay the listing says a few weeks lol
      01-22-2024, 12:02 PM   #13
shimmy23
F15 daddymobile
shimmy23's Avatar
2358
Drives: GS X5
i can only find the actual rubber piece, not the entire black housing.
      01-22-2024, 01:16 PM   #14
Drives: 2018 f85
Have you tried klifex website
      01-22-2024, 01:33 PM   #15
shimmy23
F15 daddymobile
shimmy23's Avatar
2358
Drives: GS X5
Tony, that woulda been too easy
https://klifex.com/klapan-vakuumnogo...5976-724807350
      01-22-2024, 01:33 PM   #16
Bobby_Drake
390
Drives: '16 X5M
So you guys don't have to go through returning and trying to get a refund on the wrong part, I'd like to clarify the correct one since I've just replaced mine.
See the attached photos. Notice the difference in the shapes of the end where the hose connects. I've marked the incorrect one with an X. The other piece is the actual one off my F85.
I initially was sent the wrong one from eBay and after going back and forth, etc. I just ordered the right one from a different seller.
      01-22-2024, 02:02 PM   #17
tfunk88
Drives: F15 X5 50i
It’s listed on Amazon, but for $5 more than on eBay. And then looks like direct purchase from their website is the cheapest of all
      03-28-2024, 01:20 PM   #18
bmray
Drives: BMW X5M
Ordered mine direct from Klifex and got to watch the shipping track the small piece all the way from Ukraine...should have just Amazoned it lol.
tfunk88204.00
xbimmers
