09-01-2023, 06:50 PM | #1 |
Rep 5
Massage seat retrofit possible?
Hello everyone,
I have a 2014 650I coupe with every option except for massaging seats. Which is weird because I have the upgraded ventilating seats but no massage function. Seeing that the seats are the same as the massaging seats, i was wondering if i could just buy the panel with the button and code it in. Any help would be much appreciated! |
09-01-2023, 08:36 PM | #2 | |
Rep 2,926
09-02-2023, 03:01 PM | #3 |
Rep 7,588
Ditto…its just bladders that lift/lower each butt cheek to prevent fatigue on long journeys…or if you actually have a sore hip or pelvis…the gently rocking may give some little bit of relief. The massaging (active) feature on the f06/f12/f13 is not as advanced as the newer massaging seats that have active bubbles in the upper back section…but neither our type or the new type are like getting a jujitsu massage like those chairs in the mall…or a deep tissue massage from a masseuse. This option is only to prevent fatigue…not give you a massage that could actually put you to sleep. You’re driving, not sitting in your home trying to relax.
The action of the active seat feature simply does what you do when sitting for a long time…we tend to shift our bodies form one cheek to the other (basically rocking our pelvis which gives some relief from sitting in a stationary position for a length of time)…the active seat feature does this gentle rocking for you. If you are driving for a long distance, it really can help prevent fatigue from sitting in the same position for hours. But if you’re just running to Wally World to pick up a gallon of milk…you will probably find it weird or annoying as mentioned in the post above. Index Explanation 1 Seat surface, left front seat
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 09-06-2023 at 08:36 AM.. |
09-26-2023, 03:08 AM | #5 | |
The Dovahkiin
312
Rep 150
You're in Los Angeles, if you want to see how they feel, let me know; I'll grab the M6 and take you for a ride to feel the disappointment. I can almost guarantee you will no longer worry about them.
Ed
CG Artist, Set Painter and Sci-Fi Nerd. “The problem with the world is that the intelligent people are full of doubts, while the stupid ones are full of confidence.” - Charles Bukowski |
10-01-2023, 04:21 PM | #6 |
Rep 1,833
Drives: BMW iX Xdrive40 MSport
Besides the hardware requirements (bladders, pumps, valve blocks) you will also require wiring, coding and a significant amount of manual labour.
I installed a lumbar bladder with massage from aliexpress on my ex-650i F12 and that was pretty hard work.
Current: iX Xdrive40 | MSport | 22" Bicolour | Amido Interior | Mineral White Metallic |
