10-31-2007, 12:52 AM | #1 |
Rep 13
Anyone know what run-flat tire will the 1er be using???
I went up to Tirerack.com and found a bunch of run-flats any guess on which ones will come with the car? And if you were to get new rims and tires are you stuck with getting towed if you get a flat?
[SIGPIC][/SIGPIC]I am the ONE to Bling!
10-31-2007, 01:09 AM | #2 |
Rep 2,781
Drives: 2020 M4 ZCP / 2023 X3 M40i
I'm guessing the same kind as the E90. Just get a fix-a-flat kit.
10-31-2007, 10:23 AM | #5 |
Rep 2,067
10-31-2007, 10:40 AM | #6 | |
No longer moderate
325
Rep 4,401
A separate set of Blizzacks WS-60s on 17" wheels may be the trick. Teslaastro is in FL so he hain't seen snow in awhile (I would suspect). BTW, the WS-60s were developed because you Cannucks complained about the tread pattern on the WS-50s being squirrely during lane changes in slush ; -). |
10-31-2007, 10:50 AM | #7 |
Rep 10,176
My e90 has Bridgestone RE 050A runflats stock. They are decent as daily driver tires in the wet. Heck, I left them on for the past two winters up here in Massachusetts too. I certainly wouldn't recommend that, but I've driven in the snow with them (and they did suck, as expected).
10-31-2007, 03:06 PM | #9 | |
Rep 2,067
Unfortunately, I won't live long enough to see the benefits of global warming - warm sunny weather and palm trees in Toronto in January..:headbang: |
10-31-2007, 03:16 PM | #10 |
No longer moderate
325
Rep 4,401
11-01-2007, 02:13 AM | #11 |
Rep 13
This is the review I found for this tire.
http://www.freshalloy.com/site/marke...0a/default.asp So it turns out to be not bad of a tire other than the fact that you may have to change them once a yr. (Once every 3 months for some of us who love putting solid strips on the streets).
