XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
Register FAQ Calendar Today's Posts
      10-03-2023, 12:01 PM   #1
Aro321
Drives: BMW 135i
X1 35i Maintenance
Group,
I really just need some guidance to the thread that probably already exists.
I just picked up a 2014 X1 with 100k miles and want to tackle the maintenance.
I'm planning on
- Water pump/thermostat/ coolant
- Control Arms
- Transfer case fluid
- Trans fluid
I need to know if there are other important areas of focus on this chassis that needs attention.
ie: bushings, suspension, engine mounts
I have the n55 and I'm already very familiar with what the engine will need but want to get the chassis right and protect what I've got.
Any direction or experience the group can lay on me is appreciated! Thanks
2003 E46 M3 Topaz
2016 F80 M3 Alpine
      10-03-2023, 12:16 PM   #2
Allworth
Drives: X1 xDrive20d (E84)
Here is a list what I've done so far recently that may be relevant.
Thanks
I would also add a new belt, tensioner, and idle pulley to this list unless already replaced.
Battery is likely to be still factory, worth checking if it holds charge well.
Full computer diagnostic of course to check for any errors in sensors.
1995 E34 525td auto • 2016 F30 320ed auto
Aro3210.00
      10-08-2023, 07:30 PM   #3
sudermatt
Drives: 2015 X1 35M
Around 80k you could start looking at your motor mounts. They are liquid filled and can start leaking.
      10-11-2023, 01:53 PM   #4
maxwmiller
Drives: 2013 X1 xDrive2.8i
I have seen a few N55 guys report issues with their radiator leaking.
Of course, BMW is famous for chronic issues with the cooling system in general, so watch for any leaks and be proactive in replacing cracked hoses.
xbimmers
