10-07-2023, 11:28 AM | #1 |
Rep 1
Fixed: DME not switching DME relay on
As the title suggests.
I can manually switch the relay on by grounding the control line and then everything works. I traced the wire to the DME and it seems perfectly fine. I attached a probe to the pin of the DME and at no point does the DME drop the pin to ground like it should. I have ISTA/INPA. The only fault code is the EKP complaining that the DME relay is not switched on. Im guessing my only option is to try replacing the DME? Edit: found 2 pins on ECU were corroded and missing Last edited by unclerhino; 10-08-2023 at 04:51 AM.. |
