11-14-2007, 06:43 AM | #1 |
NRA Life Member, BMW CCA 30 year member
181
Rep 2,614
Tip for a black 1-Series...
Tip for a black 1-Series; airbrush Tamiya Smoke on the side markers for the appearance of an uninterrupted side panel.
Resigned 1ADDICTS Moderator
To disarm the people is the best and most effective way to enslave them. George Mason |
11-14-2007, 10:55 PM | #4 |
Rep 722
11-16-2007, 11:02 PM | #6 | |
181
Rep 2,614
1) Remove 'offending', clear, side-marker lens, 2) Airbrush Tamiya-brand 'Smoke' onto said lens for a smooth, factory-stock looking production, 3) Reinstall now-modified lens. The above assumes said side-maker lens(s) can be removed.
11-17-2007, 04:31 PM | #9 |
Rep 2,012
I did it with my suby. Baked the headlights for 15 mins at 250 degrees to soften the seal. unscrew everything, and the headlight pops open, is it the same ordeal for bmw headlights from before?
11-18-2007, 02:30 PM | #10 |
181
Rep 2,614
Should the lens be emphatically attached to the car, simply masking around the lens could be done. That might actually be one heck of a lot easier. The image approximates the effect as I have eliminated the side marker while dimming with Smoke will not completely visually remove the thing.
04-05-2008, 12:05 PM | #11 |
181
Rep 2,614
As it turns out, the little side-marker/lens is actually a turn signal. That's unfortunate.
04-05-2008, 02:28 PM | #12 | |
Rep 459
I bet you were feeling this. Now what are you going to do?
~My other car is a Blackhawk~
[SIGPIC][/SIGPIC] |
04-05-2008, 02:48 PM | #13 |
181
Rep 2,614
Leave it be, as it turns out, once the car is in your hands, little things like the side marker become inconsequential.:wink:
04-05-2008, 03:09 PM | #14 |
Rep 459
Ouch. Knowing I won't see my car for months he strikes the mortal blow.
[SIGPIC][/SIGPIC] |
04-06-2008, 01:42 PM | #15 |
181
Rep 2,614
Wasn't my intention...:iono: Hang in there, the wait is worth.
