12-01-2007, 04:58 PM | #1 |
Rep 9,034
PROcede issues thread.
http://www.e90post.com/forums/showthread.php?t=98321
Just an FYI that not all issues are worked out yet. |
12-01-2007, 10:32 PM | #3 |
Rep 1,329
ultimate performance is not always the easiest thing to achieve. you can always settle for less performance but if you can handle it being the beta tester can have its advantages.
12-01-2007, 10:37 PM | #4 |
Rep 10,176
IMO, the V2 was released before it should have been released. Shiv not was meeting his well published teaser posts and his "coming very soon" timelines, felt the pressure to get it out, and now have a ton of beta testers that can be a support nightmare. I think that because of all the other options coming out, he felt he had to release it (not to mention the extra $$ he made from releasing it).
Five months from now, there will likely be more options, and more refined/tested versions of current offerings.... just in time for the release of the 135i. :smile: |
12-01-2007, 10:49 PM | #5 | |
Rep 1,329
12-01-2007, 11:00 PM | #6 |
Rep 9,034
12-02-2007, 10:56 AM | #7 |
Not a Newbie
Rep 173
Shiv also promised a Procede type piggyback for the new turbo Cooper S....about 6 months ago. Seems that his ability to time product releases are approaching OEM. That said, I have no knowledge of the quality of his product.
[SIGPIC][/SIGPIC]
12-02-2007, 12:16 PM | #8 |
I like beer
32
Rep 1,286
Personally, I think BMW should release their own ECU upgrade. I would be willing to settle for a little less performance with 100% peace of mind. Like they said in that thread, quality first, then performance.
12-02-2007, 01:15 PM | #9 |
Rep 1,329
ofcorse you need a good exhaust and maybe an intake. Vishnu have hit over 400 whp so far with nothing but cat back, PROcede and 98 octane with a few more months of tuning I don't see it to be impossible to have a readily avalibul map that will give 400whp on 93 octane. read up a little
http://www.e90post.com/forums/showthread.php?t=93865 |
12-02-2007, 02:14 PM | #11 |
Rep 1,396
Don't bother with reading the original thread from the OP. It is and amazing waste of time.
The actual issue that the flame thread was actually talking about is addressed in a completely different thread: http://www.e90post.com/forums/showthread.php?t=98472 |
12-02-2007, 06:16 PM | #12 | |
Rep 9,034
And the there are a few threads with people complaining about the PROceed. The linked thread was interesting because 2 people who were total fanboys of the unit have gone a different direction. |
12-02-2007, 09:35 PM | #13 | |
Rep 184
Either outcome would hurt BMW. Also, read up on the pollution control regulations in regards to non-stock ECU's. |
12-03-2007, 09:01 AM | #14 | |
Rep 1,329
I'd never call the PROede a guaranteed easy no issue mod. I honestly think half the people that buy it are getting in way over there head. ever notice all the people breaking electrical connectors. |
12-03-2007, 12:33 PM | #15 | |
Rep 106
12-03-2007, 01:42 PM | #16 |
Acquiring the taste.
Rep 151
No, there isn't. While there certainly are many larger turbos available, only a very small subset of those will actually fit in the default location. Like many of the S2000 turbo modifications, significantly larger turbos will have to be moved further to the front and rear of the engine bay, if there is room at all.
12-04-2007, 08:45 PM | #17 | |
Rep 106
12-06-2007, 12:07 PM | #18 | |
Under the radar
41
Rep 840
That'd be nice, but then you're going to have to figure out how to sufficiently fuel them. Direct injection isn't exactly easy to modify, and there isn't much headroom left at all. :frown: |
12-08-2007, 04:06 PM | #19 |
Rep 290
There are a couple guys modifying the stock turbo's (I believe just some porting and fin/blade changes) and supposedly with the changes they can push another 2-3 psi at the top end without needing any fuel related upgrades. That should be good for around 16-17 psi max or a efficient 15psi. From the outside, no one could tell the difference between stock or not because its all internal. At 16 psi at 6k rpm I bet you'd hit 425whp on pump gas. I think this is the best next step for those who want to appear stock with a fairly cheap upgrade. I plan on doing this after some more beta testing.
12-11-2007, 12:59 PM | #20 | |
Rep 146
2010 135i Coupe | Black Sapphire Metallic | Red Leather | Poplar Grey Wood Trim | 6MT | Premium pack | M Sport pack | Heated Seats | HK Premium sound | USB | Smartphone integration | Automatic high beams
01-07-2008, 10:57 AM | #21 |
Constantly Learning
66
Rep 200
The majority of the problems seem to be due to installation errors. Also, one was due to the dealer not securing the oil fill cap. The latest version seems to be rock solid with amazing gains.
01-08-2008, 07:47 AM | #22 | |
Rep 4,822
