12-08-2007, 05:19 AM | #3 |
Rep 312
I'm assuming you're talking about the 135i?
The 135i wheel/tire combo is: Front - 18 x 7.5 with 215/40/18 Back - 18 x 8.5 with 245/35/18 I think what you mean is the actual "dish" of the spokes. On the front the spokes are flush & straight, and the backs are set back a bit, with the spokes curving inward a little. I have not seen them in person, but I've looked at a ton of pictures of the 135i wheels, and that's the way I see them .:smile: |
12-08-2007, 05:43 AM | #4 |
formerly izzo/comeback
287
Rep 3,382
as seen in this pic... there is a very subtle diff of the rear wheels have a deeper lip...it may even be a shadow..but def. an aftermarket thou with the staggered fit it will look amazing
BMW CCA # 418268
12-08-2007, 06:46 AM | #5 |
Rep 10,176
gbent is correct. the rear wheels have more dish to them than the fronts, giving it a bit more of an aggressive look. They look pretty good in person. Here's a pic I took that shows the difference in dish. Both sets of spokes are concave, but the rears are moreso.
12-08-2007, 08:09 AM | #8 | |
Rep 10,176
By the way, the Bridgestone RE-050A runflats on these cars are not directional, but do have an inside and outside. That means you can swap side to side, but not front to rear. |
12-08-2007, 03:51 PM | #9 |
Rep 222
We'll see, but 911's have a rear-biased weight distribution that demands a stagger to keep the back from coming around. I anticipate rear sway plus a non-staggered setup to get neutral on the 1.
12-08-2007, 11:50 PM | #10 | |
Rep 21
Maybe, if you buy high grip tires for the 135i you can fit bigger tires up front. So instead of being 215/245 front to back, it could be 235/245, or even 245/245. The reason being that with more grip from the tires, it will be harder for the engine to break the rear loose. So you won't have much need for a staggered set up to compensate for oversteer, and you can increase you total traction by both improved compound and increased contact patch. Also, I don't care about the fact that you can't rotate the tires at all. I am much more concerned about the performance of the car of the car than about the economy of it. If you're concerned about tire wear, fuel economy, and stuff like that buy the 128i. |
12-09-2007, 08:29 AM | #11 |
Rep 222
Pretty much every rwd car sold in America understeers significantly. This is because the auto makers see this as a safety feature. The 135i's out-of-the-box understeer has been discussed on this board a good bit already.
My concern about rotating tires is that you can get a lot more from track tires if you can swap them front to back, and some r-comps are bi-directional in dry conditions (toto ra-1, for example). The excellent falken rt615 is bidirectional too. I just don't see that a staggered setup for a weight balanced car makes sense, except that it looks cool. Sure, there are ways to dial out the understeer without changing the wheels (more camber in front, mostly), but then you make even more of an issue of tire wear. |
12-09-2007, 08:43 AM | #12 |
Rep 10,176
Good point, R32. I was going to mention camber plates when I posted about the swaybars, but thought a lot of people wouldn't normally use them because of premature tire wear. Adjustable swaybars (like UUC) will likely easily dial out the understeer on the coupe, keeping the stock camber and tires, while not effecting wear.
You're also correct that this has been discussed quite a bit in other threads. That deep dish does look cool though, to get back on topic. :smile: |
12-09-2007, 09:10 AM | #13 |
Rep 22
12-09-2007, 06:34 PM | #14 |
Lucky Lefty
Rep 746
Drives: on twisty roads
Garage List 2019 BMW M2 Comp [0.00]
2017 Porsche Macan GTS [8.00] 2011 M3 [10.00] 2013 bmw F25 msport [10.00] 2011 335iS [9.60] |
You can really see the concave nature of the wheels in this picture:
The Power of M |
12-09-2007, 06:51 PM | #15 | |
Rep 1,015
It may not be like this .. I had 18x9s up front and 18x10s in the rear of my 04 cobra and I didn't really have any understeer with this setup .. actually it hooked really well in regards to being a dragger ..(if you mean straight line performance).. Crowley
The last words on the powerplant should go to a clearly overwhelmed Hormazd Sorabjee, editor and publisher of Autocar India: “There is something simply magical about BMW’s in-line six. It has a creamy smoothness that makes velvet feel like sandpaper.” |
12-10-2007, 09:25 AM | #16 |
Rep 42
My dealer tells me that BMW does not recommend tire rotation unless you do it every 3,000 miles or less because the tread sets. You screw up the set if you rotate say every oil change.
12-10-2007, 10:07 AM | #17 |
Santa Fe Concorso
104
Rep 2,984
I'd like to see if some of the euro guys that are taking delivery soon would test the 18x8.5 wheel/tire setup in the front and report back to the forum if it works without issues.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
12-20-2007, 08:10 AM | #18 |
Rep 34
I have
-Front 205 45 18 wheel 7,5 x 18 -Rear 225 40 18 wheel 8 x 18. In future I'll buy in front 215 40 not Run on flat. However I think that different tyre width between front and rear isn't a good setup. I can subscrive this solution only in the 135i with 305 hp. In other models this cause only under steering. In order to avoid it I adjusted the front camber to -2° 13'. |
12-20-2007, 09:29 AM | #19 |
Santa Fe Concorso
104
Rep 2,984
Freno a mano, please tell us how you adjusted front camber? Did you install camber plates, or is there an easier and cheaper method?
12-20-2007, 09:47 AM | #20 |
Zoom Zoom
38
Rep 1,069
He explained it pretty well in this thread:
http://www.1addicts.com/forums/showthread.php?p=45703 This is a technique that works for almost any car (at least any car that I have come across with this sort of front suspension). It should help address our theoretical understeer problems without resorting to the aftermarket.
In the garage: 2022 G80 M3 Manual - Portimao Blue
12-20-2007, 10:04 AM | #21 | |
Rep 1,329
12-20-2007, 10:11 AM | #22 |
Rep 34
In my previous car I had to rotate. In 1 series you have only to remove the centering pivot, lift the car, loosen up the dome nuts and adjust the camber as you want. It requires only 30 mins. After that you have to adjust also the toe.
