11-10-2023, 02:47 PM | #1 |
Rep 134
Any negatives if I don't replace a leaky valve cover?
Just wondering what happens if I don't replace a leaky valve cover. It's been diagnosed by a local shop but it's a pretty pricey replacement because the valve cover is like $700-800 plus a bunch of labor. Just wondering if there are any negative side effects (other than an oil smell) if I don't get it fixed.
11-10-2023, 03:03 PM | #2 |
Rep 1,088
Drives: Lots of BMWs
Garage List 2018 M4 Vert [0.00]
2006 Z4M Roadster [0.00] 1995 540i [0.00] 2008 BMW M5 [0.00] 2019 i3 Rex [0.00] 2021 X7 40i MSport [0.00] |
It's just a $50 gasket, don't see why the actual cover would need to be replaced.
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX 2021 X7 40i MSport, 2006 Z4M 6spd |
11-10-2023, 03:18 PM | #3 |
Rep 134
11-10-2023, 05:10 PM | #4 |
Rep 2,091
I just replaced the gasket on mine, not too bad of a job. If your valve covers not making any squeeling pcv noises then you're good to just change the gasket.
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD |
11-10-2023, 07:49 PM | #5 | |
Racecar Driver
1323
Rep 2,003
Drives: BMW M4
I would just order a valve cover off FCP Euro and replace it while you're there. The PCV is something that fails eventually.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
TractionControlDelete4604.00 G35POPPEDMYCHERRY4998.50 |
11-10-2023, 08:24 PM | #6 |
Rep 68
11-11-2023, 04:09 PM | #7 |
Rep 587
If you're approaching ~70k miles your PCV valve is provably close to failure anyway; replacing the entire valve cover will save you paying the exact same labor expenses again pretty shortly.
11-11-2023, 06:28 PM | #8 |
Racecar Driver
1323
Rep 2,003
Drives: BMW M4
My PCV failed at like 4.5 years / 41K miles and the labor wasn’t cheap lol. If there is any work that requires the valve cover to be removed and it’s not only a few months old… swap that thing lol. So to anyone that has work that needs to be done with the valve cover removed, just get a replacement from FCP euro. My SA told me that valve cover replacements/PCV failure is common and they only last a couple of years.
N1rve
11-12-2023, 11:34 AM | #9 |
Rep 1,015
I have 118K miles on my original valve cover and gaskets. I have some light sweating but nothing to warrant a replacement yet. Since i can DIY, i would probably only replace the gasket if it started forming drops at the bottom... If you plan to keep the car for a while and you cant DIY, it might be best to replace the valve cover in your situation.
I dont agree with the "Your PCV will go bad soon, replace it" argument. |
11-13-2023, 03:19 AM | #10 | |
Racecar Driver
1323
Rep 2,003
Drives: BMW M4
N1rve
