12-10-2023, 04:53 PM | #1 |
Rep 362
2016 F80 S55 Teardown
Enjoy! Nice engine!!! Watch over-rev valve float I guess! Money shift?
https://youtu.be/ydVUo11eiRc?si=06gNwbTvDtAd0XwO
Dont be humble, give me that rumble. 2022 F95 X5MC, 2020 G05 40i, 2016 F86 X6M (sold), 2014 328ix F30 (totaled), 2009 e91 328ix (sold), 1997 740i e38 (nikasil fail)
12-10-2023, 05:59 PM | #3 |
Rep 362
I Do Cars is addictive. You want to understand what’s moving the machine, it’s great to see what’s inside!
Subscribe as he is a hard working, funny guy. Look up the n63 and other BMW engines as well.
12-10-2023, 10:06 PM | #5 |
Rep 362
As Eric mentions, the machining is great. You can see differences when you watch other engine Teardowns.
There are things you pick up that are interesting (IMO): -head bolt lengths longer than n versions. Must be a reason! -you understand why those are 1x use aluminum bolts. They break! -the valvetronic cam snaps back so fast! You can understand how it has to be that way for throttle response purposes. -the wear on the main bearings was strange relative to the rod bearings in decent shape. ?? 🤷🏻‍♂️ -cool oiling systems. -belt driven water pump preferred over electric. -check out those hollow cams. Cool. -the intakes were rather clean for DI engine. Maybe walnut blasted. And the machining of ports is nice to see. Clean edges between intake valves. Lots of good info in these vids.
NickyC17683.00 |
12-13-2023, 08:10 AM | #7 |
Rep 571
Enjoyed that
Dgjo2022X5MC433.50 |
12-13-2023, 08:29 AM | #8 |
Rep 2,408
11:10. Guy is hilarious.
12-13-2023, 04:31 PM | #9 |
Rep 25
Not sure Eric knows just how prevalent the crank-hub slip is on the S55. I wonder if his assessment in the end (valve float from over-rev) would be different if he knew that. I just don't understand how slipped timing wouldn't cause this.
12-13-2023, 06:07 PM | #10 |
Rep 362
Maybe over rev causes valve float for intake and not exhaust, amd slipped timing would impact (literally) all valves?
Also seems to me the slipped timing failures I have seen have bent valves. This engine seemed not to have that.
12-13-2023, 06:49 PM | #11 | |
Rep 10,737
Drives: M4 CS. Former G82, x2 F82, F80
Fun video. The sections where he talked about the rod bearings, meh. Another non issue with the S55. |
spidy512502.00 |
