02-15-2008, 10:33 PM | #1 |
Rep 466
Replacing Run Flats on Stock Wheels
Any ideas as to the best set-up that will fit on the stock 135i wheels? I've seen 225/40/18 front and 255/35/18 rear in a few posts. Would 230 tires fit in the front?
02-15-2008, 10:44 PM | #3 |
Santa Fe Concorso
104
Rep 2,984
The 235x40 could be made to fit, but they wouldn't be best for performance. Stick with 225x40 on the 18x7.5 OE wheels. JMO.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
02-16-2008, 01:31 AM | #4 |
Rep 1,474
Drives: 135i MT, LMB, ProNav
So are we saying that stock tyres will fit on the OE rims? I thought that the OE rims are specially designed for run flats.
If stock tyres fit, I wonder whether the air pressure monitoring system will work?
Fun Car: 135i Manual LeMans Blue / Beige Leather / Grey Poplar / pro nav / euro plates. Delivered 24 June 08 Family Car: Land Rover Discovery 4 SDV6 Spare Car: Volvo V70 Sydney Car: MB 420SEL |
02-16-2008, 05:22 AM | #5 | |
Rep 119
I run proper Continental tyres on Hartge aftermarket 19" rims and the aire pressure system works fine.:smile:
02-16-2008, 06:52 AM | #6 |
No longer moderate
325
Rep 4,401
The Bridgestone folks in Chicago said the sidewalls and beads of the tires, of course, are different compositions for runflats, but as Rephlex has said, they use regular rims (unlike the Michelin TRX tires from years ago).
02-16-2008, 12:21 PM | #8 |
Rep 1,170
Drives: M2 Competition, E30 M3 DTM
Best tire setup for this car is on stock rims
225/40/18 fronts 7.5j 245/35/18 rear. 8.5 j With this setup you reduce understeer. Don t go with wider rear tires it only gets worse. I have no shorter gearing and the rear 245 have stil grip enough. Maybe the best setup would be 235 all round. But 235 on 7.5j rims are not nice. 8 j and 235 are perfect. But fronts are 7.5 j and rear rims don t fit on the front. They hit inside of the shocks. When my fronts are gone i go for 225/40/18. |
02-16-2008, 12:31 PM | #9 |
Santa Fe Concorso
104
Rep 2,984
Thanks, Advevo, for that real-life information. I still have hope that with aftermarket 18x8.5 wheels with proper offset (around et40, or small front spacers) that a square 245x35 tire setup will be possible. Only time, and little trial and error, will tell.
02-16-2008, 12:32 PM | #10 |
Rep 442
The last time I saw this discussed, I didn't see matching high performance summers tires available in the OEM sizes.
[I quickly checked the Tire Rack a few weeks ago.] Has this changed? One more question: What is the procedure for de-activating the Tire Pressure Monitoring System when you move to non run-flats? |
02-16-2008, 01:06 PM | #11 |
Santa Fe Concorso
104
Rep 2,984
The TPMS system on these cars includes devices and special valve stems that mount on the wheel and the electronics in the car. I have yet to hear of a way to disable the electronic system entirely, but removing the TPMS hardware from the OE wheel and installing them on different wheels works fine if they aren't damaged. You can also buy a new set of TPMS wheel hardware from TireRack, and others, for over $200 a set.
02-16-2008, 07:50 PM | #12 |
Rep 466
02-17-2008, 10:37 PM | #13 |
Rep 442
02-17-2008, 10:58 PM | #14 |
Rep 466
Based on that, I wonder if I should take the run flats off right away...potholes and rough roads are only slightly less prevalent in NY than in Massachusetts.
02-18-2008, 07:44 AM | #15 | |
That's me...
17
Rep 234
TPMS system does not include any special devices. It just senses differences in pressure using ABS sensors - which measure the rotation speed of the wheels and compares the measured speed to it's memory (set by driver) and signals if there is a difference. That's why the system needs to be reset after a tyre/pressure change - it needs to recalibrate it's memory. And it will work the same for any kind of tyres. |
02-18-2008, 07:54 AM | #16 | |
Santa Fe Concorso
104
Rep 2,984
02-18-2008, 10:24 AM | #17 |
Rep 7,594
Drives: '19 M2C
Mikeo is correct...I can confirm. I saw the special TPMS valve stems on the 135i at the Chicago Auto Show.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
02-18-2008, 11:14 AM | #18 |
Rep 448
Any implications with this new hardware and the use of a foam tire repair kit?
02-18-2008, 02:05 PM | #19 |
Santa Fe Concorso
104
Rep 2,984
Yeah, using fix-a-flat pretty much screws the TPMS on that wheel. New TPMS wheel unit is $40-$50.
02-19-2008, 02:01 AM | #21 |
That's me...
17
Rep 234
02-19-2008, 07:14 AM | #22 |
Santa Fe Concorso
104
Rep 2,984
Joey, no my bad. Direct TPMS is a USDOT requirement--I have no idea if Slovenia requires the Direct system, I would hope not.
