01-22-2024, 11:32 PM | #1 |
Crazy Frog
543
Rep 1,212
EMD springs vs. ZCP spring rate?
Does anyone have EMD springs on a Competition pack (ZCP) car? How does it feel?
I heard the EMD springs are softer than ZCP springs, but stiffer than base/non comp springs. I’d like to retain EDC so coilovers are not an option for now.
01-22-2024, 11:48 PM | #2 | |
Rep 1,696
Base Pkg Front - 177 lbs/in Rear – 591 lbs/in Comp. Pkg Front – 198 lbs/in Rear – 685 lbs/in EMD Front - 194 lbs/in Rear - 645 lbs/in
DSC, you say? Never heard of it
https://youtube.com/@tractioncontroldelete |
01-23-2024, 06:37 AM | #4 |
Rep 5,946
Except for professional racers, it’ll be impossible for the typical driver to feel the difference between a F 4 lbf/in and R 40 lbf/in deltas in spring rates. No noticeable difference in balance/handling. Also, the F spring rate is actually higher because BMW uses the bump stops to control travel so the actual spring rate is higher, particularly on lowered cars because you’re riding on the bump stops more frequently.
01-25-2024, 07:20 AM | #6 |
Crazy Frog
543
Rep 1,212
This is what I was worried about. I have Eibach pro springs on my E90 M3, feels stiffer for sure but it feels like it crashes over bumps instead of dampen it.
