02-24-2008, 10:03 AM | #1 |
Rep 80
from stock 18 to 19", what size tire to use
stock 18" rear uses 245-35-18, i was wondering what tires size should be used for 19". it should be 285-25-19 or 295-25-19, but no one sells those tires size, and 275-30-19 has like 5% difference is speedometer. anyone have an answer for me?
02-24-2008, 10:37 AM | #2 |
Rep 2,231
I dont think you can fit that much rubber on the rear. I would say 265-30-19 max imho.
02-24-2008, 11:01 AM | #3 |
Santa Fe Concorso
104
Rep 2,984
IMO, 265x30-19 in the rear will be the max without massaging the fenders. For the front 235x35-19 should work, but I'd hope and pray 245x35-19 could be made to fit without rubbage. And Toronto better have great road maintenance.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
02-24-2008, 11:15 AM | #4 | |
Car Addict!!
62
Rep 1,303
TM |
02-24-2008, 11:30 AM | #5 |
Santa Fe Concorso
104
Rep 2,984
Yes, worse, and IMO, yes. I'm staying at 18" but was trying to help the member with some information.
02-24-2008, 11:43 AM | #6 | |
Car Addict!!
62
Rep 1,303
TM |
02-24-2008, 11:51 AM | #7 |
Santa Fe Concorso
104
Rep 2,984
Waiting would likely give you more workable options alright. Exactly correct offsets will be key in maximizing wheel/tire size combos. It will be a trail and error process and it's always cheaper to let others make the errors.
02-24-2008, 12:28 PM | #8 |
Rep 3,668
damn j66...285s? I see that rubbing...badly...I think a 255/30/19 might work for the rear and that is a fairly common size.
on a side note...I have 235/30/20 on my a6 with eibach springs and it still has a really comfortable ride...
02-29-2008, 02:47 PM | #10 |
Rep 57
from the performance side 18 are better, 19's also required some pretty skimpy rubber that doesnt leave much cushion
my .02, find out the widest rubber that fits up front and put it all the way around, combat understeer. |
02-29-2008, 05:48 PM | #11 |
Rep 153
That would help with rotating the wheels/tires front-to-rear. A thicker RSB will probably go a long ways towards eliminating most of that understeer as well. Nate
02-29-2008, 09:01 PM | #12 |
Call
21
Rep 683
Beyern 5 20x10 with Pirelli Pzero Nero 285/25ZR-20 rear; 20x8 1/2 with 245/30ZR-20 front from my 335I. I guess I need to sell them since I don't have much of a chance of putting them on my 1er?
Call |
03-01-2008, 12:33 AM | #13 |
Commander
Rep 320
whats the offset?
FS: CT9A parts and Enkei Wheels!!! PST
BLUEFAKES.COM ARE SCAMMERS, LIERS, AND CHEATERS! DO NOT BUY FROM THEM!!! |
03-06-2008, 05:30 PM | #14 |
Rep 20
If you change your wheel size don't change your tire size, you'll just mess with your torque and horsepower numbers. I think I am going to go with 18's on the front and 19's on the rear with g-force tires. Yaaaaaaaya :headbang:
03-07-2008, 12:55 AM | #15 |
PCA, BMWCCA
102
Rep 2,058
Schnitzer uses 225/35-19 on all their 19" applicatins (et 43).
'08 Carrera S 6MT Guards Red/Black ext leather, Carbon fiber pkg, sport exh, sport chrono +, PASM, Nav, Bose, 19" forged turbos, red tranny tunnel
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU |
