01-29-2024, 02:54 PM | #1 |
Rep 72
Where are the center jacking points on a 2020 F82
Hi: I am trying to find where the best center jacking points would be on 2020 M4 F82.I can find where to jack one side at a time in the manual,but I want to jack the front and rear so both tires are off the ground,front or rear.
Lots of info on YT,but not much for the newer M4's,that I can find. I also read somewhere that jacking on the rear diff is not a good idea. Is there somewhere in the front and rear center that can accept a floor jack,maybe if you could share a link? Thanks,H50 |
01-29-2024, 05:36 PM | #2 |
Rep 1,380
There aren't any. This car is very difficult to jack up. Some people use the reinforced belly pan for the front and the rear control arm bushing housing for the rear. Just don't jack the rear from the differential cooling fins.
MGM Ext, SO int, Euro IKON, CS front lip, Carbon 1.5 diffuser, GTS/CS coding, M perf rear spoiler, & everything else STOCK.
(Previous E39 and NA1 NSX owner) Those were the days! |
01-29-2024, 07:47 PM | #3 |
Rep 72
01-29-2024, 10:01 PM | #4 |
Rep 896
Drives: F87 M2CS
I've used the central belly pan cover skid plate in the front. For the rear I used a jack pad adapter and placed it in the rear subframe just in front of the differential. Agree with above, do NOT jack using the diff fins you will crack it
MY18 F82 M4
Austin Yellow / Black / DCT / MPE |
Huck5011.50 |
01-29-2024, 10:38 PM | #5 |
Rep 1,015
Here with pics. https://f80.bimmerpost.com/forums/sh....php?t=1346090
Huck5011.50 |
01-30-2024, 09:28 AM | #7 |
Rep 5,943
In one of my M or non-M owner manual’s actually shows the BMW official front and rear central jacking points which are in agreement with the image in post #5 (only shows the one center location on the rear subframe). I’ll see if I can find it.
Huck5011.50 |
