02-16-2024, 02:16 PM | #1 |
Rep 201
Race Suspension Maintenance, Bearings, Etc
Sup Fellas,
I've got aftermarket coil-overs front, height adjustable perches in the rear, TC Kline camber plates, adjustable links etc. I live in a humid climate in Louisiana and usually try to avoid driving the car in the rain as to keep all of the exposed bearings, spherical bearings etc clean from the elements. It all gets a little noisy after a while. MCS advised to spray the bearings with some PB Blaster, allow it to sit, then blow out with compressed air. Anyone have any maintenance tips, thoughts, routines? |
02-16-2024, 03:12 PM | #2 |
Rep 5,960
There’s not much you can do unless there are options for a sealed/covered monoball/bearing. I believe all of the upper and lower rear suspension arms from Ground Control are sealed. Fall Line used to offer race and street (sealed) rear arms. PB blaster, or similar products, do a good job of loosening up debris + compressed air (works far better than water and keeps the bearings/monoballs lubed).
Damper covers/sleeves can be used to protect the piston rod and spring seats (thrust sheets or Torrington bearings) from dirt and debris. I’m using them on my wife’s f22 240ix with MCS 2WR dampers because it is occasionally (not purposely) driven in winter road conditions. They do a great job of keeping the dampers clean. You can use zip ties to better seal the sleeves to the dampers. |
02-16-2024, 03:38 PM | #3 | |
Rep 201
