03-16-2008, 08:09 AM | #1 |
Rep 105
335i UR Downpipes Fit the 135i!!
I've test yesterday the 335i UR downpipe and they fit in 135i.
About procede,v 1.47 work good,but when I install the v2 appear a yellow engine ceck.... Hower with v2 at 80%(before the engine ceck light appear) +50hp and 85Nm:biggrin: |
03-16-2008, 08:30 AM | #2 |
Rep 10,176
Great news, Kompey!! Do you have any pics of the install of the DPs?
Too bad about the v2 throwing a CE and limp. I'm now wondering if the Procede needs a different version for the 135i... |
03-16-2008, 08:50 AM | #3 |
Rep 2,231
Are you sure your check engine and limp are not a result of running catless downpipes? Do you have 02 sims in place? If not i would say your limp mode is more related to running catless than to the v2. Just a guess.
03-16-2008, 09:13 AM | #4 | |
Rep 105
I reinstall it on may:wink: About procede I think there is a different turbo boost sensor.... I've test the procede without downpipes:wink: |
03-16-2008, 09:23 AM | #5 | |
Rep 2,231
So just to clarify v1.47 ran fine. Just v2 threw codes right? |
03-16-2008, 09:30 AM | #6 |
Rep 822
I will not be going the PROcede route when chipping... they may get the most power but... they get the most limps and problems.
Current: 135i, 323i wagon. Sold:GTI Sold: FX45 Sold: E36 M3 |
03-16-2008, 11:05 AM | #8 |
Rep 2,231
I think this is simply a byproduct of the amount of people running the tune. More people = more problems. Furthermore, most of the limp issues that I have read about have been caused by a screwed up install. I personally know about 5 people that have been running v2 without so much of a hiccup. Just some info.
03-16-2008, 11:23 AM | #9 | |
Rep 105
With the diagnosis the problem is high turbo boos pressure I've sell my procede to a friend with 335i and now I'm waiting for the new AA xede that is specific for 135i |
03-16-2008, 11:26 AM | #10 | |
Rep 822
03-16-2008, 11:37 AM | #11 |
Rep 2,231
You are correct but then again we arent exactly comapring apples to apples here. JB and SSTT are way less complicated than the V2 as they are simple plug and play tunes. Helix is way more comparable to the V2 but it has just been released and barely and handfull of people have it. All are good tunes. I would think that more complicated a tune is, and the more people have it, the larger the potential for problems will be.
03-16-2008, 11:48 AM | #14 |
Acquiring the taste.
Rep 151
Don't confuse a check engine light with limp mode.
03-16-2008, 12:00 PM | #16 |
Rep 2,231
03-16-2008, 12:15 PM | #17 |
Rep 2,626
Actually, based on dynos it would seem that Helix makes a measurable amount more power. Also, the current fastest 335i is a JB2 car, none of the procede cars, even Shiv's personal car with a more agressive tune, and race gas has managed to catch it in the 1/4th.
'08 Black Saphire/Black Z4 M Coupe
RIP Gretta: Blue Water/Lemon 135i. Died to save me. -ChuckV |
03-16-2008, 06:51 PM | #19 | |
Rep 610
That is not true, someone just posted over at E90Posts and there are numerous people with properly installed Procede having all types of problems. Not to mention Scalbert found a flaw in the way the Procede boosts and because of that Shiv is releasing a new version with a new map, soon. So, alot of people for the last 3-4 months have been having an over boost issues and complaining to shiv about them, it took another board member to investigate and find the issue before Shiv would even respond. Not to good of support from that camp. Procede will NOT be going into my car, simply because of the massive amounts of problems and unsafe boost levels. Specially since Active Autowerk just released a brand new device and another company, Helix seems to be getting great reviews, both for $700 bucks. |
03-17-2008, 02:30 AM | #21 | |
Rep 105
It isn't sure that the problem is the procede,it could be a different setting problem:wink: |
03-17-2008, 08:15 AM | #22 | |
Rep 469
Darryl www.ultimate-racing.com |
