03-02-2024, 04:27 PM | #1 |
Rep 502
Can this be cleaned or is it embedded into the paint
I found this on my rear wheel yesterday I talking about the thing on the very lip it doesn’t go way with soap is there a cleaner I can use it not curb as it feel raised as oppose to sunken in
03-02-2024, 04:47 PM | #2 |
Racecar Driver
1323
Rep 2,000
Drives: BMW M4
It might just be baked on brake dust. Have you tried a more aggressive brake cleaner like SONAX?
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
03-02-2024, 05:02 PM | #4 |
Rep 1,166
Drives: 2022 M340i Mineral Grey
Diablo is garbage, sub-par product. I would try P&S brake buster, any iron decontamination and an all purpose cleaner diluted strongly. If that doesn’t work, after spraying down the wheel with a good lubricating soap, use a clay mitt or clay towel to see if that removes the contamination.
Present: 2022 M340i Mineral Grey
Past: 2019 330i, 2012 Evo X GSR |
1heckinboi44.00 hC1001610.00 |
03-02-2024, 06:09 PM | #5 |
Rep 5,899
It does looks like baked on brake dust. Follow the recommendations by peelerec. Brake dust can be extremely stubborn to come off after repeated heat cycles especially after getting wet.
03-02-2024, 06:25 PM | #6 |
Racecar Driver
1323
Rep 2,000
Drives: BMW M4
Diablo Gel is one of the reasons why I never buy Chemical Guys stuff anymore LOL. Sonax is one of the best wheel cleaners I've ever come across. It smells like death though.
N1rve
03-02-2024, 06:37 PM | #7 |
Rep 650
I have a terrible amount of baked in brake dust.
The guy I bought them off said it was from endless brake pads. I tried claying a small section but it only reduced it a bit Ideally I need a soft buffer in the shape of the one in the photo attached and a product that will shift it. Can some post the name of the Sonax wheel cleaner? Thanks |
03-02-2024, 06:50 PM | #8 | |
Racecar Driver
1323
Rep 2,000
Drives: BMW M4
https://www.amazon.com/Sonax-Beast-W...ustomerReviews
N1rve
03-02-2024, 07:13 PM | #9 | |
Rep 650
I bought a range of Sonax products. All very good. I bought that wheel cleaner and it cleaned the wheels quite well but didn’t make any impact on that baked in dust |
03-02-2024, 07:31 PM | #10 |
Rep 1,378
Looks like oxidation or salt damage to me and I don't think that will come off. But if you think differently, disregard opinions in a vacuum here and take it to a professional detailer.
MGM Ext, SO int, Euro IKON, CS front lip, Carbon 1.5 diffuser, GTS/CS coding, M perf rear spoiler, & everything else STOCK.
(Previous E39 and NA1 NSX owner) Those were the days! |
03-04-2024, 11:24 AM | #11 |
Rep 502
I was thinking that it could be salt damage as well but then again it only in one wheel so I’ll try the wheel cleaner it like $20 before I go get them fixed
03-04-2024, 11:25 AM | #12 | |
Rep 502
03-04-2024, 12:37 PM | #13 |
Rep 5,899
Salt damage usually shows up as pitting and/or bubbling/cracking in the paint. From your picture, it looks like a substance that is sitting on top of the painted surface.
03-04-2024, 01:03 PM | #14 |
Rep 502
03-04-2024, 01:23 PM | #15 | |
Rep 5,899
Have you tried a clay bar? This usually does a good job of removing stubborn stuff from wheel surfaces. |
03-04-2024, 05:26 PM | #16 |
Rep 650
03-06-2024, 03:46 PM | #17 |
Rep 650
I got this hard cut foam tip that runs off a drill via an extension thinking I could get in and access the endless brake pad built up dust(previous owner said the pads were the cause)
I could target the area but barely any shifted I need a product that will soak and somehow loosen up these baked in deposits? Imagine it will have to be something very strong. |
03-09-2024, 07:29 AM | #18 |
Rep 650
I cleaned them with Iron x. Did a decent job but for the baked in part in the rim behind the spokes it required serious rubbing with neat iron x and a Microfibre.
It’ll take forever at this rate! |
03-09-2024, 10:38 AM | #19 |
Rep 5,899
Man, that sucks. I had this happen on my s2000 wheels and it took my 3-4 weekends and a lot of elbow grease. The ‘00 s2000 had a very simple 5-spoke design and it still required 6-8 days to clean the wheels. 763M are more difficult to clean. Do you have a different car to drive while you clean your wheels? I did and that’s what allowed me to eventually get the wheels cleaned. Good luck!
jaylazy2020267.00 |
03-09-2024, 10:42 AM | #20 | |
Rep 650
I should put on the 666m wheels with winter tyres that have become wall art in my gaf! I just love the 763m so much now I’m looking at a second set but with Cup 2 for summer. I think your right though. Take them off an get them properly cleaned The rears are mint and look so much better than the fronts! |
