BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
      03-27-2024, 08:00 PM   #1
soursamo
soursamo's Avatar
Drives: 2008 E92 M3
KW HAS Kit with Bilstein?
Does anyone know if any of the Bilstein front struts work with the KW HAS kit or only the OEM ones do?
Thanks.
      03-28-2024, 12:35 PM   #2
M3SQRD
M3SQRD's Avatar
2477
Drives: E92 M3,G20 330ix,F22 240iX,F82
Only works with OEM damper which has a larger diameter than the Bilstein damper. Also, the Bilstein lower spring mount/seat is welded to the top of the damper.
soursamo166.50
      03-28-2024, 03:11 PM   #3
tsk94
tsk94's Avatar
Drives: E92 M3, E82 128i, F82 M4, E36
The HAS kit won't work as mentioned above.
You could do something like this GC kit though: https://groundcontrolstore.com/colle...cs-jrz-ast-etc
soursamo166.50
      03-28-2024, 04:30 PM   #4
M3SQRD
M3SQRD's Avatar
2477
OP - I’d recommend calling GC before purchasing their kit for Bilstein. I believe this kit is for Bilstein motorsport dampers, not their inverted strut street dampers. Just verify if this spring kit is compatible with the B16. It won’t work with the B4, B6, B8 and B12 dampers.
tsk941526.00
soursamo166.50
      03-28-2024, 09:51 PM   #5
soursamo
soursamo's Avatar
Drives: 2008 E92 M3
Thanks everyone, really appreciate the info!
m3post
