03-29-2008, 05:21 AM | #1 |
Rep 1,657
has anyone dynoed a 135 on a dynojet?
i just entered the numbers from the road and track tests of the 135 and 335 into a calculator that gives you crank hp from quarter mile times, speed and weight.
for the 335 sedan, it weighed over 3815 pounds and hit 13.5 @ 104.5 for the 135, it weighed about 3520 pounds and hit 13.4 @ 104.0 Now the calculator said the 335 is making 323 hp at the crank. which is inline with the 275hp at the wheels we've been seeing on dynojet. For the 135 the result was 300hp at the crank. This is not in line with the dyno posted of the 135i which shows something like 279hp (done by MWerks i believe). But there is an explanation, this dyno was not a dynojet. it was a dyno that measure hp without the wheels. So, are there any dynojet dynos of the 135i stock? If the calculator is accurate, they will be in the 250 to 260 hp range. I hope its wrong. |
03-29-2008, 06:58 AM | #2 |
Rep 153
I wouldn't worry about it. The 135i blows the 335i away as the speed increases above 80 mph. Both cars are have similar HP but are traction limited at lower speeds. The weight, aerodynamics and power of the 135i shine through at higher speeds. Nate
03-29-2008, 09:33 AM | #3 |
Rep 7,594
Drives: '19 M2C
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
03-29-2008, 10:21 AM | #4 |
Rep 5,627
Seems like the weights are a bit skewed as BMW specs the (manual) 335i sedan at 3594 lbs. and the 135i coupe at 3373 - a 221 lb. difference, not the 295 lbs. you quoted. Also, the sedan has a Cd of 0.30 vs. the coupe's 0.33.
Tom |
03-29-2008, 11:05 AM | #5 | |
Rep 610
Same engine, same HP! The 135i is 200+ lbs lighter than the 335i coupe. Acceleration wise, the 135i should be slighter faster than the 3 series in all categories of acceleration. Performance wise, the 135i will outhandle and outbrake and pretty much best the 3 series aswell. Which is why BMW made this car! |
03-29-2008, 02:04 PM | #6 | |
Rep 1,657
03-29-2008, 02:08 PM | #7 | |
Rep 1,657
you may have a point with the Cd (Cd is not the amount of drag btw, its just the drag coefficient, there's a thread on this around here), but I'd still like to see a real dynojet dyno. |
03-29-2008, 02:10 PM | #8 | |
Rep 1,657
In any case, I'm curious about the HP. |
03-29-2008, 02:58 PM | #9 | |
Rep 5,627
While I brought up the Cd, I wonder how much it actually affects the 1/4 time. (I assume the coupe's frontal area is similar to the E90 sedan.) Tom |
03-29-2008, 09:32 PM | #10 |
Rep 283
03-29-2008, 11:37 PM | #11 | |
Rep 2,626
That's a good 15-20rwhp stronger than your average 335i. Don't post that on E90post though! You're likely to get your head torn off for suggesting that the 135i isn't detuned compared to the 335i!
'08 Black Saphire/Black Z4 M Coupe
RIP Gretta: Blue Water/Lemon 135i. Died to save me. -ChuckV |
03-30-2008, 03:00 AM | #12 | |
Rep 1,657
thanks. 262hp sounds about right. That's close to what I predicted in the original post. |
03-30-2008, 03:43 AM | #13 |
Rep 2,626
That's on a mustang. Equivalent to about 300rwhp on a dynojey. Actually, it's more power than I've seen a 335i make on a mustang. ~260 whp on a Mustang is equivalent to ~340 hp at the crank.
03-30-2008, 01:06 PM | #14 |
Rep 1,657
the guy who posted the mustang dyno said "they tend to read 10-20% lower then most other dynos (Dynapack, DynoDynamic,ect)" Dynapack and DynoDynamic read higher than Dynojets. Also, his statement was about mustang dynos in general after "reading up" on them, not about the specific dyno he used and the specific correction factors used by the dyno operator.
The thing about mustang dynos is that they are very sensitive to the correction factors the operator puts into them. I've seen mustang dynos that will read higher than dynojets because of the correction factors. the truth is, unless we see what that same mustang dyno reads for 335's we don't really know what that 262 number means. But, it's possible the operator entered correction numbers to get numbers comparable to a Dynojet. |
03-31-2008, 12:31 PM | #16 | |
Rep 2,626
Also, in my experience, I've found mustangs to be the least variable of the dynos I've used. Tends to be quite consistant. My figure of 12% dif from Mustang to Dynojet is one that is widely used in the world of american muscle. Assuming it's reading the SAME as a dynojet, that's still well within the normal range for an N54 car. 260-280 seems to be the 'normal' dynojet range. Out of curiosity, how did you arrive at those numbers? By my calculations, from C&D's data panels, I get 135i: 13.3@106/3420=318 335i:13.6@105/3557=321 Calculating based on trap speed. If I use ET, I get 335i: 279 135i: 287 Basically identical.
03-31-2008, 12:37 PM | #17 |
Rep 1,938
So I guess the short answer is no, nobody has put one on a Dynojet yet. Most people are probably still in the break in phase and dont want to whomp on it yet.
03-31-2008, 12:47 PM | #18 | |
Rep 1,015
Once I am out of the break in period . .I'll be getting on a dynojet here ... I'm sure by then though others will have done this .. lol .. Crowley
The last words on the powerplant should go to a clearly overwhelmed Hormazd Sorabjee, editor and publisher of Autocar India: “There is something simply magical about BMW’s in-line six. It has a creamy smoothness that makes velvet feel like sandpaper.” |
03-31-2008, 12:49 PM | #19 |
Rep 7,594
Drives: '19 M2C
I wasn't sure if you we're using the Dynjet brand Dyno as a generic term or not. Many people refer to a dyno as a dynojet.
05-23-2008, 05:34 PM | #20 |
Rep 7
Dynojet produces the most consistent dyno results from run to run, although not always the most accurate. I only look for dynojet results to compare. Otherwise, there can be large variations from other dyno systems.
06-21-2008, 01:54 PM | #21 |
Rep 3,094
My car weighs 3360 with a full tank of gas and on a dynojet I pulled 263rwhp. Car only had 1100 miles on it at the time and only a 1/4 tank of gas.
I should be getting more runs in this week, but I dont know if they will be stock set up runs. |
06-21-2008, 04:18 PM | #22 | |
Rep 1,657
did you do your dyno in 4th gear? and was the correction factor set to STD and smoothing to 5? there's a post on n54tech about how the 335 guys dyno, so that we can compare numbers: http://www.n54tech.com/forums/showthread.php?t=488 they don't do everything for "accurate" numbers, but if you don't do it like that, you're numbers won't be comparable. 263hp is kinda around what i expected (see my first post). unfortunately 335's put down like 275.
"KOPEYKA" /// Titanium Silver / Black Leather / Gray Poplar / Sport Package / Premium Package / 6MT / Feb 08 Production |
