04-02-2008, 02:55 PM | #1 |
Mr. Brand Loyalist
41
Rep 418
grille install....how to.
install takes no more than 5-10 mins... here's how:
The circled areas are where the clips are located (7 total) -first using a "L shaped" pick, unclip the 2 bottom clips that are visible -then gently pull the grille partially out, the 2 side clips will then unclip themselves(do not pull too hard as the top 3 clips are still locked) The 4 torx screws(circled) need to be removed(forgot the size.... sorry) -then gently lift the top part of the bumper... this will allow you to see the remaining 3 clips. -next use the same pick to unclip the 3 remaining and the grille will come out. -then take pics and post them:thumbup: on 1addicts.com
Current: 1M, M2cs
Retired: '08 135i,550GTxDrive, etc. |
04-15-2008, 02:18 PM | #2 |
Individual1
Rep 141
Thanks to your instructions I was able to change my standard black kidneys to 135i style chrome ones! Took less than 10mins after I'd found the right L-shaped tool for the clips.
Here's a shot showing the driver side kindey removed. The holes for the clips are easy to spot here! Driverside installed: Both replaced with chrome: Success! :headbang: |
04-15-2008, 03:30 PM | #3 |
Rep 145
how much were the grills?? i would like to do this to my 123d,
123d M sport, Sedona Red, Boston Black Leather, 261s, Xenons, Bluetooth, USB, Brushed Aluminium, Darkened Glass, Cruise Control.
05-07-2009, 01:55 AM | #7 |
Rep 694
Drives: BMDUBS
could you please update the pictures on your photobucket??
