Next Level Auto Brokers
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M3 (F80) and BMW M4 (F82) General Forum
      04-27-2024, 11:17 PM   #1
f82shawn
Drives: 2017 M4 Competition
Need Help Diagnosing M4 Issues
Hello, I have a 2017 M4 Comp that I picked up a few months ago. Had left it stock until about 1000 miles ago, when I decided to get some vrsf catless downpipes, and a stage 2 tune through BM3. Everything was going fine with the car, no problems, and was ripping on it consistently. Then a few days ago, car goes into limp mode during a pull, followed by a CEL, and after I scan it, it comes up as a misfire on cylinder 4. No biggie, I suspect it was ignition coils or spark plugs, so I order a tune up kit through FCP Euro with the OE Delphi coils and OE Bosch plugs. The next day, I install the parts and re flash the car and clear the codes. Everything seemed to be running smoothly, but then when I went to turn on the car in the gym parking lot, it turned on, then shut off 3 seconds later, same deal 3 times over, until the 4th try it decides to stay on. Problem sort of stopped, but idle was rough for about 20 seconds when starting car cold, the shut off issue came up a couple more times here and there, but the car seemed to be doing it less the next day. Then, later in the day, the car goes into limp mode on the freeway, so I scan it out when i get home. I get hit with quite a few codes, instead of just a misfire on cylinder 4, it said it detected a misfire on cylinder 4, 6, 3, and 1, as well as code 120408: Boost pressure control, and 108C01: charge air temp. Flashed it back to stock and it seemed to be running fine, then flashed back to stage 2 and was running fine for about 45 minutes. Scared to drive the car again, trying to diagnose what could possibly be going on. Any advice would be appreciated, thank you.
      04-28-2024, 12:14 AM   #2
1heckinboi
caffeine fiend
1heckinboi's Avatar
44
Drives: M4
Have you checked the coolant level for the intercooler already?
      04-28-2024, 10:29 AM   #3
Busa1
Busa1's Avatar
Drives: M4 and 435i xDrive M-Sport
Could it be the plugs you used? Did you get the correct ones (1 step colder I believe) and gap them properly to work with a Stage 2 tune?
      04-28-2024, 02:23 PM   #4
krudmunk
Drives: F80 M3
Try NGK 2 step colder plugs and gap them properly for your tune.
      04-28-2024, 03:01 PM   #5
f82shawn
Update, put about 50 miles on since I cleared codes, car isnt having a rough idle or misfiring, but went into limp mode so i scanned it again. no misfire codes, but I have the ones that follow: 120408 (boost pressure control, shutdown as a follow-up reaction), 108C01 (charge air temp too high), 20A201 (charge air cooling system: coolant pump protective function active due to dry running).
      04-29-2024, 08:48 AM   #6
f82ryan
Drives: m4 2015
Check your top mount intercooler seems like a code that it’s empty
      04-29-2024, 10:03 AM   #7
b_w.
Drives: F80 M3
Mis fires are probably tied to coolant leaking. Likely need a new tmic. Look at OEM or if you want aftermarket go Wagner. Will want to change your oil.
      04-29-2024, 10:15 AM   #8
N1rve
Racecar Driver
N1rve's Avatar
Drives: BMW M4
2019 BMW M4  [9.63]
You need a new TMIC.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension
      04-29-2024, 11:34 AM   #9
Jmk508
Drives: M4
Perfect time to upgrade. Just installed a Wagner unit and fitment was great!!
      04-29-2024, 01:20 PM   #10
f82shawn
You guys were right, checked intercooler reservoir and its definitely leaking somewhere. My question is once replacing it, how should I clean out any trace of coolant? Obviously flush oil and replace, but how else and where should I clean residue as I suspect I’ll find some probably in intake manifold once I pull the intercooler, and what should I use to clean. Cheers
      04-29-2024, 01:23 PM   #11
f82shawn
Also as far as aftermarket solutions, is wagner best route to go? I know CSF has one for same price, and was debating the VRSF one as its 3x cheaper, but not too sure how much quality is sacrificed at that price. Any input is appreciated, cheers.
      04-29-2024, 04:02 PM   #12
gcant35
gcant35's Avatar
24
Drives: 2015 BMW M4
I too am curious about the quality of the VRSF top mount ic, I've had one sitting in my garage for months I got from a buddy who sold their car. Haven't installed it yet since the OEM unit seems more than efficient in terms of cooling and IATs (until they leak).
      04-29-2024, 05:12 PM   #13
NSX2M4
NSX2M4's Avatar
1420
Drives: 2019 M4 ZCP- RIVIAN R1S QUAD
I'd rather just buy an oem one every 4-6 years TBH.
MGM Ext, SO int, Euro IKON, CS front lip, Carbon 1.5 diffuser, GTS/CS coding, M perf rear spoiler, & everything else STOCK.
(Previous E39 and NA1 NSX owner) Those were the days!
      04-29-2024, 07:34 PM   #14
N1rve
Racecar Driver
N1rve's Avatar
Drives: BMW M4
2019 BMW M4  [9.63]
Wagners or Mishimoto. If you live in a CARB legal state your option would be Mishimoto or another OEM. Though be mindful that an OEM one is 1/2 the price and if you get through FCP Euro, you would have lifetime replacements on that item.
CSF has been shown to decrease performance so I don't recommend it to anyone and I think this is also lacking a CARB #.
I have not heard too much about VRSF.
N1rve
f80post
