04-20-2008, 02:23 AM | #1 |
Rep 905
found a better intake but it's more expensive
For all you who did not like the bms because it was so close to the engine and worry about the heat issues. This has a bit more distance from the engine
http://www.jlevistreetwerks.com/p1708/Logic-Motorsports-HVI-Intake-System-335i,-135i-%26-535i/product_info.html?osCsid=6028b961dc28442e6dbbc5125 a8e0294 if you have already seen this then, sorry! |
04-20-2008, 09:01 AM | #2 |
Car'a'carn
473
Rep 751
Uh but now it really is just sucking in hot air. At least the filter options are still hitting the incoming air from the kidney vents
04-20-2008, 12:25 PM | #5 | |
Car'a'carn
473
Rep 751
I still prefer a nice CAI or the BMS filter as it still gets air from the front air ducts |
04-20-2008, 12:36 PM | #6 |
///M
13
Rep 138
Seems like factory air box is still the way to go as long as hot air intakes are the only option.
"She blows more than my mind" - RHCP
*Aerodynamics are for people who can't build engines. |
04-20-2008, 11:09 PM | #10 |
Got Boost?
52
Rep 601
Seems like a horrible design. I just can't really see how any other intake system will improve on the OEM design, it's a dual kidney ram air intake. You can replace the filter with a K&N panel filter
04-21-2008, 01:17 PM | #11 | |
Rep 9,034
I figure it doesn't hurt to have a heat shield. |
04-21-2008, 01:20 PM | #12 |
drk one
38
Rep 797
Drives: 2008 135i
ugh... still gonna have to stick with filter drop in.
04-21-2008, 01:21 PM | #13 |
Rep 1,015
It will be interesting to see if there are any gains found with the BMW performance filter kit ....
Crowley
The last words on the powerplant should go to a clearly overwhelmed Hormazd Sorabjee, editor and publisher of Autocar India: “There is something simply magical about BMW’s in-line six. It has a creamy smoothness that makes velvet feel like sandpaper.” |
04-21-2008, 01:36 PM | #14 | |
Car'a'carn
473
Rep 751
The formula to figure the ideal outlet temperature is: T2 = T1 (P2 ÷ P1)0.283 Where: T2 = Outlet Temperature °R T1 = Inlet Temperature °R °R = °F + 460 P1 = Inlet Pressure Absolute P2 = Outlet Pressure Absolute |
04-21-2008, 01:51 PM | #15 |
Rep 56
04-21-2008, 07:15 PM | #16 |
BMW ONE
15
Rep 630
Drives: 93 RX-7 R1, 135i
Most tuners have said the factory box is a limitation as the power goes up.
135i - Alpine White - Black Leatherette - 6-Speed - Sport Package - Aluminum trim - 6FL
04-22-2008, 12:41 AM | #17 |
Rep 309
Factory for sure.
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car 1989 Honda Civic Si-R Current Project 2002 Corolla CE Daily Driver www.TheTunerSource.com |
04-24-2008, 11:30 PM | #18 | |
Rep 1,764
Orb |
04-25-2008, 03:12 AM | #20 |
Rep 2,042
That kit is a rip off...just a bit of plastic drain pipe+ a K&N haha. What you really need to do is locate the filter in the front bumper somehow totally out of the engine bay. I have done this on other cars and it means that intake air is same as ambient. Means longer intake pipe length though. I do not know if this is achievable on the 135i.
04-25-2008, 06:36 AM | #21 |
I like beer
32
Rep 1,286
Someone needs to develop an intake like the J's racing or Mugen intakes for the S2K. They have a "snorkel" to direct cool air from the front of the vehicle to the filter. The snorkel actually encompasses the filter, so it's not sucking in air from the engine bay.
This shouldn't be hard to do with the 1. Just make a piece that connects to the existing ducts and houses the high flow filter. |
