04-21-2008, 06:18 PM | #1 |
Rep 204
Pic Request - 19" CSL
I am getting my car in June and the only wheel I want to put on my car is 19" CSL. I have yet to see this setup (not ps). Is anyone knowledgeable enough to tell me if the following fits without rolling fender?
8.5 et 40 (4mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 22mm) 9.5 et 45 (6mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 20mm) Thanks so much in advance! |
04-22-2008, 03:52 PM | #2 |
Rep 214
I found a AW hatch with 19" CSL on the hatchback forum
here is the link: http://www.1addicts.com/forums/showthread.php?t=7726 I personally want the 19" csls as well... but i'm just scared that they might rub.... so I think i will just stick to 18".... |
04-22-2008, 09:06 PM | #4 |
grebo guru
Rep 64
If I am not mistaken, CSL stand for Coupe Sport Lightweight or the German equivalent anyways. The CSL wheels are from the unavailable in the U.S. E46 M3 CSL.
There are many replicas out there and similar OEM wheels were available on the E46 M3 ZCP, or Competition Package (the fronts in the U.S. were 0.5" narrower, 8.0" v. 8.5" on true CSL). I hope that makes some sense.
Shane | def.con.one Racing |
04-22-2008, 09:52 PM | #6 | |
Rep 204
Does the hatch has the same offset as the coupe? It seems to fit the hatch quite well and if they have the same offset and fender flare, then its going to look great on the 135i. Anybody know? |
04-22-2008, 10:03 PM | #7 | |
grebo guru
Rep 64
ZCP front: 19x8.0, et 47 CSL front: 19x8.5, et 44 I read that Matt (the white hatch owner) is running four CSL fronts w/ 235s. I PMed him and he has not had any issues. original post by Matt: http://www.1addicts.com/forums/showt...6588#post96588 HTH,
04-22-2008, 11:56 PM | #8 |
Rep 214
Here are some site that have them for sale...
I've sent e-mails to both of them and they have confirmed that the wheels fit on 1ers. European auto source: http://www.europeanautosource.com/in...009a69af48c00b Mod Bargain: http://www.**********s.com/search.aspx?si=&sp=CSL Hope it helps!!! |
