04-26-2008, 10:39 AM | #1 |
Rep 4,190
What a PITA.
Has anyone opened the ECU housing yet? I just tried and what a PITA it is to get to. I didn't get that far because I didn't want to start unbolting pieces.
04-26-2008, 10:47 AM | #2 | |
Addicted Member
15
Rep 603
I'm sure they did that for a reason
[SIGPIC][/SIGPIC]
04-26-2008, 11:31 PM | #4 |
Rep 131
c'mon, it's not hard guys. simple as a matter of fact.
1. remove the six 8mm screws holding the microfilter housing and remove the housing 2. remove the square cowl piece on the right side 3. remove two more 8mm screws holding down the cowl 4. lift the cowl up and slide out. 5. the e box cover has 2 slide locks and 2 'hook' locks with a lock on each side. slide the slide locks to the open side and unhook the hook locks with your finger or a pick tool of some sort and remove the ebox cover. should take you less than 10 minutes. |
04-26-2008, 11:41 PM | #5 |
///M
13
Rep 138
At least its easy to access in the engine bay. For my current car I had to solder wires under the steering column. Not the most pleasant experience. I am looking forward to be able to work on this car standing and being able to see everything clearly.
"She blows more than my mind" - RHCP
*Aerodynamics are for people who can't build engines. |
04-27-2008, 10:47 AM | #6 | |
Rep 4,190
05-02-2008, 12:00 PM | #8 |
Rep 309
Bosch making the best stuff!
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car 1989 Honda Civic Si-R Current Project 2002 Corolla CE Daily Driver www.TheTunerSource.com |
05-02-2008, 06:07 PM | #9 |
Rep 43
so, tuned, please tell me... all these ECU stuffs are not going to void any warranty even though you have to mess around such way?? I am kinda skeptical.. I want to have warranty on my ride.
05-09-2008, 02:27 PM | #11 |
Rep 309
Split second makes a realy good kit too.
