05-02-2008, 07:35 AM | #1 |
Rep 631
Aftermarket tires on the stock 264 oem wheels ?
What are the largest tires F and R that should be used on the stock 264's? Keep in mind that I plan on lowering about an 1" also.
Front are 7.5" and rear are 8.5" Can someone confirm the offset of these F & R? Thanks |
05-02-2008, 08:04 AM | #2 |
Santa Fe Concorso
104
Rep 2,984
Offset info is in a sticky at the top of this forum.
Some people are doing 225x40 and 255x35 on the OE rims.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
05-02-2008, 08:21 AM | #3 |
Rep 631
05-06-2008, 01:34 AM | #5 |
Rep 79
Do I understand this correctly? A wider front tire will help conteract some of the understeer. If I were to increase both front and rear up one size would the understeer still be there?
05-06-2008, 08:12 AM | #6 |
Santa Fe Concorso
104
Rep 2,984
Most likely, since the relative difference is still there.
