06-23-2008, 09:19 PM | #1 |
Rep 4,311
Drives: Supercharged E90 M3
Brakes Screech All The Time.......
my brakes screech all the time?
im not hard on them, i have a little over 800 miles on my car. whats wrong? anybody elses car doing this too? thanks, Jeff
06-23-2008, 09:51 PM | #2 |
Santa Fe Concorso
104
Rep 2,984
First time I've heard that regarding the 1-Series. Take it to the dealer, if nothing else is wrong they can at least put some anti-squeal compound on the back of the pads.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
06-23-2008, 09:58 PM | #3 |
Rep 4,311
thanks buddy!
ill do that.
06-23-2008, 11:04 PM | #4 |
Rep 5,970
This is a new one it seems.
I don't hear a sound out of my brakes, even when I'm hard on them, so I'd say something is up with yours. Could be as simple as the anti-squeal backing as mentioned above, but it could be a sign that something needs a little work. |
06-24-2008, 05:11 AM | #5 |
NRA Life Member, BMW CCA 30 year member
181
Rep 2,614
Screeching is a new one. Your dealer's service department should be able to sort it out. You'll be fine.
Resigned 1ADDICTS Moderator
To disarm the people is the best and most effective way to enslave them. George Mason |
06-24-2008, 09:35 AM | #6 |
La Flama Blanca
27
Rep 1,545
In InsideLine's long-term test blog, they complained about the squealing as well. And the brake dust. :iono:
AMS, Berk Technology, aFe, ER
06-24-2008, 09:55 AM | #7 |
Rep 531
Did you bed in the brakes beforehand? If not, do so. If it STILL screeches, go to service.
This is a general guide, but the concept is the same: http://www.zeckhausen.com/bedding_in_brakes.htm
06-25-2008, 09:09 AM | #10 |
Santa Fe Concorso
104
Rep 2,984
If any small bits of gravel get wedged between the pad and rotor it will definintely make a noise.
06-25-2008, 09:48 AM | #11 |
Rep 1,201
Drives: 2015 M235i, 2017 Tundra
and damage your rotors
06-26-2008, 05:51 PM | #13 |
Rep 117
Just rebed the pads. In other words do a number of 60-5mph hard stops and then let the car sit so the brakes can cool off. Another thing you can do is remove the pads and bevel the edges down. A lot of brake pads nowadays don't have the sharp 90 degree edges, but instead you'll see the edges at a small 45 degree cut (bevelled). This helps prevent a bit of squeal. Dremel works best to do it.
07-22-2008, 01:42 PM | #15 |
Rep 6,968
Argh those really sucks.... small pebble cause hundreds of dollar
- There's nothing in my pocket other than knives and lint
07-29-2008, 04:48 PM | #16 |
Rep 4,311
i took mine in and i had a cracked brake pad, so they replaced them, but they still screech.
08-12-2008, 03:17 AM | #18 |
Rep 1,657
my breaks made the loudest highpitched sound i have ever heard tonight. definitely sounds like the break sensor problem
"KOPEYKA" /// Titanium Silver / Black Leather / Gray Poplar / Sport Package / Premium Package / 6MT / Feb 08 Production |
02-17-2009, 12:41 PM | #19 |
Good life
130
Rep 1,937
My car has been doing this too for the past 3 months! I had only had it for 4 months before it started screeching. I plan to go to the dealer (just haven't had time). Silverbullet- have your brakes gotten better since the dealer fixed them?
02-17-2009, 01:19 PM | #20 |
Unindicted co-conspirator
66
Rep 1,734
Drives: to work, mostly.
Someone said (maybe on this forum? Can't recall: )
Europeans don't care if brakes squeak, as long as they work. Americans don't care if brakes work, as long as they don't squeak. Since asbestos was banned, squeaky brakes (as long as we're not talking about the squealer indicating that the pads are worn out,) are just the price of having performance brakes on a performance car. |
02-21-2009, 05:34 PM | #21 |
Good life
130
Rep 1,937
^Not on a car that cost me $38k. Maybe a ford taurus. And for the record, my brembos on my STI never squealed, even after 2yrs of owning it. I've barely had the car now for 6 months and I def don't brake late or hard brake. The dealer should fix the problem so I'm not too worried.
