      11-17-2008, 05:52 AM   #1
Alext
Drives: B M W
How to remove trunk liner to access 3rd brake light?
Do those plastic pop rivets come off by levering with a screwdriver or do you need a special tool? I tried with a screwdriver and an old rag but was a bit afraid to use too much strength just in case i broke something.
      11-17-2008, 06:01 AM   #2
Lester
Drives:
Use a tool like this:
      11-17-2008, 06:29 AM   #3
Alext
Drives: B M W
Ah ok thanks Lester
      11-17-2008, 09:27 AM   #4
Lester
Drives:
They pop right out. You should be able to get this type of tool at any parts/tools retailer.
      01-01-2015, 04:37 PM   #5
cbl117
cbl117's Avatar
Drives: 2013 e92 335i
I had a similar question to OP and didn't want to create a duplicate thread so I'm brining this one back from the dead.
Does anyone know where I can find the mentioned tool to remove the rivets? Does it have a name I can reference?
CURRENT: 2013 TSM 335i 6AT | Stock!!...for now |
SOLD: 2010 CR 135i 6MT | 351 WHP 387 WTQ | Dinan Stage 2 | Dinan Intercooler | BMS DCI | Berk Street Axle Back | N55 Midpipe | BMWP Y-Pipe | Bilstein HD Dampers | BMWP Springs | Whiteline RSFB Inserts | 225/255 RE71R | CDV Delete | CF Diffuser |
      01-01-2015, 05:44 PM   #6
Pig Farmer
Drives: E92M
Here's your best bet:
http://t.harborfreight.com/5-piece-a....google.com%2F
If/when you need to remove other push rivets and tabs around the dash, doors, front bumper, etc., the nylon pry bars won't mar the finish of the part being removed.
      01-01-2015, 06:05 PM   #7
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
This might help you out...
DIY third LED brake light replacement...
http://www.1addicts.com/forums/showthread.php?t=845005
      01-01-2015, 09:56 PM   #8
cbl117
cbl117's Avatar
Thank you both. This is perfect.
1addicts
